:: ECS Tuning :: R90 Wheel & Tire Sets // Countryman JCW Rotors // Rally Lights Lens
Bald tires? Curbed wheels?
Start the season right with some clean new wheels and fresh rubber. Everything you need to mount on the car and drive - while skipping the trip to the tire shop!
Includes a set of four 17x7" ET48 MINI R90 BBS Alloy Wheels, 205/45 R17 Pirelli P Zero asymmetrical Run Flat High performance tires and MINI Center caps.
Fits:
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
R56 MINI Cooper /S/JCW (2007+)*
R55 MINI Cooper Clubman /S/JCW (2008+)*
R57 MINI Cooper /S/JCW (2009+)*
R58 MINI Coupe /S/JCW (2012+)*
R59 MINI Roadster /S/JCW (2012+)*
*JCW 4 Piston Brake kits will need 25mm spacer for fitment
Click HERE for the R90 Wheel & Tire Set .
MINI R60 Countryman JCW Geomet® Rotors
We're excited; and with good reason. ECS Tuning proudly introduces our new line of premium, corrosion-resistant rotors: GEOMET.
GEOMET is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish that fights rust far better than paints or other conventional coatings.
Slotted or drilled and slotted, you can expect your new GEOMET rotors to outperform and outlast stock rotors, and look great behind your alloy wheels.
Fits:
R60 MINI Countryman JCW (2013+)
Click HERE for MINI Countryman JCW ECS Geomets or for more information.
MINI Shift **** / Emergency Brake Upgrade Trim Kit
This kit was made to upgrade your MINI interior center console with JCW GP 2 and JCW trim. This kit includes some of the most popular parts to help you complete the look you want.
Shift Towards Style.
R55 MINI Cooper Clubman/S/JCW (2008+)
R56 MINI Cooper/S/JCW (2007+)
R57 MINI Cooper Convertible/S/JCW (2009+)
*Manual Transmissions
Click HERE for MINI Shift **** / Emergency Brake Upgrade Trim Kit or for more information.
MINI Gen 1 Oil Filter Removal Tool
The pros know. Doing the job right means having the right tools.
MINI owners who demand the best for their motorcars will appreciate the Schwaben oil filter housing removal socket. Unlike ham-fisted techniques using adjustable pliers or other improvised tools, the Schwaben socket is designed to grip the cartridge filter housing cleanly and securely to prevent cosmetic damage.
Made of durable chrome vanadium, the socket has a 36mm hex-head protrusion for easy turning with an end wrench or socket.
Order now and have one on hand for your next oil change.
Fits:
Click HERE for MINI Gen 1 Oil Filter Removal Tool or for more information.
MINI Rally/Driving Light Lenses
Cracked, abrasion-blasted lenses don't just look bad, they reduce the effectiveness of your driving lights. Restore the good looks and lighting efficiency of your driving/rally lights with original MINI glass lenses.
MINI uses real glass because it is tougher and more scratch resistant than plastic. Even glass wears out, however, as the lights are battered by road hazards and abrasives. In the end, new lenses are the only fix.
Some dis-assembly and gluing is required to install these lenses, but the results are well worth the benefits to the discriminating MINI owner.
From See to Shining See
Fits:
R55 MINI Cooper Clubman S/JCW (2008+)
R56 MINI Cooper S/JCW (2007+)
R57 MINI Cooper Convertible S/JCW (2009+)
R58 MINI Coupe S/JCW (2011+)
R59 MINI Roadster S/JCW (2012+)
R60 MINI Countryman S/S ALL4 (2011+)-
R61 MINI Paceman S/SX/JCW (2013+)
Click HERE for MINI Rally/Driving Light Lenses or for more information.
R50/R53 MINI Cooper/S/JCW Floor Mat Carpet Set
Genuine OEM front and rear (4 total) floor mats add a velour look while introducing a level of weather protection to your MINI's interior.
Tastefully adorned with stitched MINI emblems, black piping guarantees color matching with your application. Stitched into the accelerator pedal area of the driver side mat is a thick velour protective insert. The reverse side of the driver and passenger mat have additional hook and loop anchor points, eliminating sliding.
Genuine MINI parts mean perfect fitment - these mats fill your full floor wells.
Genuine Style.
Fits:
R53 MINI Cooper S / JCW ( 2002-2006 )
Click HERE for MINI Floor Mat Carpet Set or for more information.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
08-05-2015 02:11 PM
08-05-2015 02:10 PM
