:: ECS Tuning :: Haynes Manual // Countryman Geomet Rotors // Gen1 Blackout Headlight
If you need technical information about your MINI, for repair or simply for personal satisfaction, a Haynes Repair Manual is a must-have item.
DIYers will appreciate the detaile procedures and reference data that have made Haynes a go-to trusted source of information, and the industry benchmark for aftermarket technical books on European makes.
Owners hungry for a better understanding of the technology and features that make MINI special will enjoy the richly illustrated, detailed explanations of vehicle components, assemblies, and operating strategies.
They wrote the book.
Fits:
Gen1
R50 MINI Cooper (02-06)
R52 MINI Cooper Convertible/S (05-08)
R53 MINI Cooper S (02-06)
Gen 2
R55 MINI Clubman/S/JCW (08-11)
R56 MINI Cooper/S/JCW (07-11)
R57 MINI Cooper Convertible/S/JCW (09-11)
No Coverage for R60 MINI Countryman or Convertible Top
Click HERE for the Haynes Manual .
MINI R60 Countryman Geomet® Rotors
We're excited; and with good reason. ECS Tuning proudly introduces our new line of premium, corrosion-resistant rotors: GEOMET.
GEOMET is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish that fights rust far better than paints or other conventional coatings.
Slotted or drilled and slotted, you can expect your new GEOMET rotors to outperform and outlast stock rotors, and look great behind your alloy wheels.
Fits:
MINI R60 Countryman Base 2011+
Click HERE for MINI Countryman ( NON S ) ECS Geomets or for more information.
MINI R60 Countryman S/SX Geomet® Rotors
Fits:
MINI R60 Countryman S/SX 2011+
Click HERE for MINI Countryman S/SX ALL4 ECS Geomets or for more information.
MINI Helix R50/52/53 Projector Blackout Headlights
These headlights are designed to look like the later Gen 1 MINI OEM HID Projector headlights but utilize H7 high and low beam bulbs. Feature plastic lenses with black housing, chrome reflective backing and black exterior rings.
They are plug and play. Add some Ziza H7 bulbs for multiple output colors.
Features:
• Manual adjustable leveling
• E-code cutoffs on the projector LHD ( left hand drive )
• Black matt housing with reflective chrome only in the needed areas.
• Black shinny trim rings to match the matte housing.
*Does not contain headlight washers.
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
*For vehicles without factory Xenon headlights.
Click HERE for Gen1 Blackout Projector headlight set or for more information.
Valeo MINI R55 Clubman Rear Wiper Blade Set
Tired of noisy, streaky wiper blades that chatter and don't clean? Restore your setup with sleek wiper arms with Valeo wiper blades in a minute with Valeo.
This pair of blades is a rear driver-side and passenger-side pair and match your MINI factory size.
Don't downgrade to a generic brand from the parts store; go Valeo and treat your MINI right!
Swap Squeak for Sleek
Fits:
R55 MINI Cooper Clubman (2008+)
R55 MINI Cooper Clubman S (2008+)
R55 MINI Cooper Clubman JCW (2009+)
Click HERE for Valeo rear wipers or for more information.
R60 MINI Countryman ECS Exact Fit Brake Lines
If you spend time and money renewing your brake hardware and linings, you ought to consider upgrading to ECS Tuning Exact-Fit brake hoses, and do the job right. These premium brake hoses are stronger, more durable, and better protected than the originals.
They are shielded in stainless steel mesh reinforcement, and coated with bright red vinyl for added protection. Available by the axle for front or rear, or as a complete vehicle set, our DOT-approved, tailored hoses fit like OE for hassle-free installation.
Premium Grade: MINI-Worthy
Fits:
R60 MINI Countryman (2011+)
R60 MINI Countryman S (2011+)
R60 MINI Countryman SX (ALL4)(2011+)
R60 MINI Countryman JCW (2012+)
Click HERE for MINI Countryman ECS Exact Fit Brake Lines or for more information.
01-04-2019 12:51 PM
minipopkart
08-13-2015 05:22 AM
08-12-2015 01:24 PM
08-05-2015 02:11 PM
08-05-2015 02:10 PM
