anybody running BBS RG-F in 15x7" for MCS??
on
I've also posted this on mini2.com but wanted to broaden the audience since I suspect there aren't that many people running this exact set-up (especially since the bigger-is-better outlook often prevails)
These are available from Tire Rack (BBS Japan, forged 1-piece) with an offset of ET42 and a weight of 10.2 lbs.........and a cost of $308 each.
More expensive than SSR competitions and around 1 lb per wheel heavier (for 15x7").
I really like the BBS mesh style, but I'm not sure whether 15" rims would look "odd". Alex recommended running 205/55/15 for street use. Anybody running this set-up, or similar ? If so, can you post some piccies (or direct me to them).
Any advice ? Would a 42 mm offset be OK on a rim of this size. What would the handling be like with a 55 series tyre; OK for everyday street use ?
Thanks,
Bill.
Thanks,
Bill.
Bbs Rg-f
Hi: I'm running the BBS RG-F 15x7 et 42 with bridgestone s-03 205/55-15 and it is great, especially on the street. Bought them from tirerack with alex as sales person. They work great, are forged, 10.6 pounds. I saved about 50 lbs of unsprung weight as compared to the r84 16 inchers with runflats. I love the set up immensly. I just did do a two day drivers ed with this set up, which reallly isn't the best tire size for track use, but it held up ok.
If I were ordering again, I would see if I could fit 225/50 size tires, which would work much better on the track... i know that 225/45 will work, but too small for street in my opinion...
I plan to burn through these bridgestones, and then use these bbs wheels for track use exclusively with track tires in size 225/45-15
I think the bbs wheels will be stronger for street and track use than SSR competition which I almost bought too...
By the way, if you purchase through tirerack, could you ask/confirm with your salesperson, probably Alex, that the wilwood 11.75 inch race brake kit will not fit this wheel... I still am trying to confirm that.
Thanks.... and have fun with this set up if you get it.........
Thanks,
Bill.
Thanks,
Bill.
I know of an MCS owner with similar set up for rim and tires lowered with H-sport springs used for street only and it's great.
I am also partial to BBS mesh rim style- looks cool. Just costs more than some other choices. 10.2 pounds is pretty darn light per rim.
+42mm offset is fine for stock or lowered MINIs in 15" rim sizes. Just make sure that the tire you select isn't too much more than stock size or about 24.5".
The 205/55-15 is very comfortable for street use and will behave well enough for spirited driving as well. Turn in response won't be as sharp as a 45 series tire but ride smoothness will be better. If your roads are poor then the 55 series sidewall will help reduce potential damage to your rims.
Does your MINI have any red in it?? Goes great with the red center caps.
For tires, which ones are you interested in?
In 195/60-15 I found:
Yokohama AVS ES100 for $74 each 280 tread wear, AA traction 20 pounds
24.2" outer tire diameter, H speed rated
Same tire in 205/55-15 is $78 each and is V Speed rated
http://www.tirerack.com/a.jsp?a=EZ3&url=/tires/Sizes.jsp&make=Yokohama&model=AVS+ES100&vehicleSea rch=false&fromCompare1=yes&partnum=96HR5ES100
In 205/55-15 there is a nice selection of performance tires from about $76 on up to $128 each
http://www.tirerack.com/a.jsp?a=EZ3&url=/tires/Compare1.jsp&width=205%2F&ratio=55&diameter=15&sta rtIndex=0&search=true&pagelen=20&pagenum=1&pagemar k=1&x=90&y=10&RunFlat=All
on
Well, I couldn't persuade my wife to swop-out her S-Lites for a set of RG-Fs so the only solution was to buy my own MCS !! I have a 2006 on order for February delivery and am still contemplating buying these wheels.
So, I'm desperately seeking some photos of 15x7" BBS RG-F fitted to a MINI or MCS with either 205/55-15 or 195/60-15 tires. I would like some nice side shots showing the entire car (from a reasoanble distance out) to get some perpective of proportion.
After eyeballing a mind-boggling array of different wheels in different sizes, I still think 16" look best, and I'm a little concerned that these 15" rims may look too small.
I know there are a few more people on here sporting these rims since my initial post (over a year ago).....someone surely must have some decent photos......please
on
Cheers!
on
My wife's MCS came with the OEM S-Lites (she likes the style) and we switch these out for the winter months with 16" steelies from Tire Rack.....maybe it's all in my head but I believe I can feel a difference in "go" and "stop". Here. we're saving around 50lbs total (since the S-lites have the 30lb all-season tires !!).
Switching from the X-Lites (which I've ordered) to something like the 15" RG-F or even 16" SSR comps will save about 40 lbs total compared to the X-Lites; I've got to believe that will also make a noticeable difference.
Saving 40 lbs in unsprung weight isn't such a big deal if you're driving around in a 997, M3 or Corvette etc. but in an MCS improving power-to-weight is probably more cost-effective than shelling out $$ on expensive mods (i.e. above & beyond the basic pulley, CAI, exhaust modsetc.).
I agree, if BBS made the RG-R or RG-F in 16" with a decent offset (ET40 to ET45) I would be first in line
You're absolutely right, Stevie, frame of reference is the key. I got my car with the 16inchers got used to them and loved them from the start. I like them so much that I bought another set - one for street, one for track (steelies for winter). I've never appreciated large wheels on a MINI, to me it is just odd. If they made your r99's in a lighter 16in. version, I'd probably buy them since the design is definitely nicer than the r84.
mb
mb
The tires are 205/50-15, as listed on the EuroStylesEast website. The car is also lowered. When I was shopping for my own wheels, the 15x7 RG-F was one I considered, but like Bill (gr8britwjh) I was also frustrated at not being able to find pictures on a MINI with stock tire diameter and stock spring height.
Originally Posted by Haywood1020
Lily Von Stoop: Is it twue what they say about 15"'s?
Oh its twue! Its twue!
The 15's with the 205/50/15's make the mini a completely different car.
Additionally, the smaller wheels make it look a lot more like a classic mini.
Why didn't I do this sooner.
Originally Posted by kapps
So what do you do about the speedo as it will read way too fast with those tires?
Additionally, My stock 17's were slow. So the two should cancel each other out, as far as keeping the milage on the car "Honest"
When, I burn through these, I will go to 205/55/15.
Should be no problems there.
on
I'd already seen Brian's "for sale" photos before I made my request for additional pics on a non-lowered MCS. They do look great on this car, but again because of the drop and the artsy angle of the shot it's difficult to get a true size perspective .
The day I buy something else will be the day that hundereds of photos of the 15" RG-F appear on NAM......I can guarantee it .
Here's a pic of the wheels on the previous owner's car.
They do look kinda small thought.
I bet they look much better in 17.
But they feel sooooo good as 15's.
on
Thanks Haywood and remember; it's not the size that matters, it's the performance .
Believe it, or not, the 15" RG-F with 205/55-15s are dead-nuts-on in terms of rolling diameter relative to the 15" Holeys with 175/65-15. BTW, they don't make these in 17". The largest they sell is 16" but they've got a really aggressive ET35 offset which isn't all that good for the MINI.
Plus, if you stick a set of Toyo T1-R tyres on there, you shed a whopping 44 lbs relative to a set of 16" X-Lites with the standard all-season runflats !
Dunno, one minute I'm all hung-up on shedding weight to improve performance and the next minute I'm thinking what the Hell, I'll just buy a set of 17" OEM R99s and be done with it
