Diameter witdh and specs 15' Hollies
Old 01-13-2017, 09:15 AM
savagetone's Avatar
savagetone
savagetone is offline
Does anyone know the diameter width and specs 15' Hollies rims trying to see if i can get a wider tire on there .
Old 01-14-2017, 09:28 AM
JimR56JCW's Avatar
JimR56JCW
JimR56JCW is offline
15 x 5.5
Old 01-14-2017, 11:53 AM
savagetone's Avatar
savagetone
Thank you Jim
Old 01-14-2017, 02:23 PM
iwashmycar's Avatar
iwashmycar
iwashmycar is offline
You can always cram a size or two wider on there so long as it clears the control arms and such!
Old 01-18-2017, 01:13 PM
minihune's Avatar
minihune
minihune is offline
OVERDRIVE - Racing Champion
Originally Posted by JimR56JCW
15 x 5.5
OEM tire size is 175/65-15
You can easily put on 195/60-15, this fits rims 5.5-7" wide and has tire diameter of 24.2" which is OEM. Load rating is 88 which is better than OEM. You can choose from H Speed rated or higher tires like V or W. Tire selection is better in this size.
Alternatively 185/65-15 or 205/55-15 will also work.
Contact Alex@tirerack.com for tire choices and more info on fitment.
You do not need to use OEM 175/65-15 tire size.
