Mini Cooper Brake Maintenance Kit Application Guide
Old 09-01-2015, 12:13 PM
Mini Mania's Avatar
Mini Mania is offline
Complete Brake Maintenance Kits for your Mini Cooper includes the following:
  • Set of Front Brake Pads
  • Set of Rear Brake Pads
  • Pair of Front Brake Rotors
  • Pair of Rear Brake Rotors
  • Set of Brake Wear Sensors
While some brake maintenance can be limited to new pads, the best solution is to replace both the pads and rotors. MINI recommends that you replace the rotors whenever you replace pads. You can 'turn' the rotors and re-use your old rotors to save some money, but be aware that turning rotors will reduce heat dissipation capacity (between the wear on the rotor and turning, you lose significant amounts of metal) and increase chance of 'warping' due to the reduced thickness.
For best performance and longevity, replace the rotors and pads at the same time!
http://www.minimania.com/Mini_Cooper...lication_Guide
andrewjg1994
01-29-2021 07:45 PM
07-16-2020 12:54 PM
08-07-2015 09:51 AM
08-07-2015 08:10 AM
08-07-2015 08:02 AM
Quick Reply: Mini Cooper Brake Maintenance Kit Application Guide
