Mid 2006 they changed to a larger lug bolt. The Bentley service manual list the spec for the smaller bolt as
120 Nm (+-10), 89 ftlb (+-7)
So on your 2014, it should be higher than that.
Page 229 of the 2013 R56 Manual (I'd imagine the R55 would be the same):
Tightening the lug bolts
Tighten the lug bolts in a diagonal pattern.
Immediately have the wheels checked
with a calibrated torque wrench to ensure
that the lug bolts are firmly seated. Otherwise,
incorrectly tightened lug bolts can present a
safety hazard.
Tightening torque: 103.3 lb ft or 140 Nm.
Replace the defective tire as soon as possible
and have the new wheel/tire assembly balanced.
Remember that the 140 nm (103 ft lb) is a dry torque. I put a couple of drops of motor oil on my bolts and torque to 90 ft lb. If you reduce the friction by lubricating the threads (or tapered surface) then you must reduce the torque value.
