Classic mesh rims F56 help
on
http://forums.vwvortex.com/forumdisp...12-Classifieds You should be able to get some good ideas on here. Maybe even find what you're looking for.
XXR 521 18x8.5" 5x112 flat black finish, flat gun metallic, or Black/machined lip, comes in two offsets.
Option for Gold, Chrome, Red, Blue or Gloss Black finish metal rivets
http://www.xxrwheels.com/xxr_521.shtml
These are but not in 5x112 pattern sadly http://www.xxrwheels.com/xxr_536.shtml
These however.. if you contact them and dont mind rep's... are available in 5x112 and bored exactly to your hub size so no hub rings are needed or you can get rings and deal with the standard 66.6mm bore size.
http://esmwheels.com/access/18-c-21_34_73.html
Stock wheels are ET54 5x112 66.6 keep that in mind. We have some wheels that fit in aftermarket but they would be very aggressive since they are on the VW and Audi side. ET 33 and such.
http://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Wheels/OEM_Alloys/
Those ^ are not RS style mesh weave... these are close.. but still not the correct style.
EDIT: And if anyone knows how low of an offset I could safely run without camber, spacers or a ruined suspension please let me know! I think I read talk about ET +35 being the lowest so far? Any confirmation?
EDITx2: Lowest offset is Vic Skimmr with ET +32 but he is running camber which id prefer not to do.
I found a website that has a huge rim selection that didn't help me too much but maybe it's of some use to you guys:
http://unleashedwheels.com
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
11-11-2015 11:59 AM
