MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Tires, Wheels, & Brakes
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post New CooperS Owner
1 Replies, 2 Views
Advertisement
Thread Tools Search this Thread
Old 03-13-2009, 08:27 PM
beasleyboy beasleyboy is offline
Gallery
Inflating very cold tires
I've neglected to check my tire pressure so I did it this morning. It was freeezing, temp barely hitting 50. I understand that the sticker behind the door says 32 PSI for cold tires. But is that when it's warm outside? Remembering my 3rd grade science, cold air contracts since molecules don't move much. Therefore, should I inflate to 32 or stop at around 30 since it'll climb to 32 when I roll for about a mile or two?
Old 03-13-2009, 08:39 PM
Deviant Deviant is offline
Send a message via AIM to Deviant
Gallery
Ideally you'd want the same pressure regardless of temp. As it gets colder your PSI may drop some and you'll have to add air but your goal is to have the same pressure in the tire at all times, not the same quantity of air.
-Ken
Old 03-14-2009, 07:50 AM
Alex@tirerack's Avatar
Alex@tirerack Alex@tirerack is offline
Vendor & Moderator :: Tires, Wheels, & Brakes
Gallery
Cold pressure is based on the ambient air temperature your driving in.
You want to set your pressures before driving.
The vehicle needs to be stationary for at least 4 hours prior to this. I prefer to do in 1st thing in the morning.
Make sure your tires have not been sitting in the sun 1st thing in the morning, it can alter pressure.
A rule of thumb is you'll loose 1 psi for every 10 degrees of ambient air temperature change . You also loose on average 1 psi a month just from heat cycles. Its a good idea to check monthly @ minimum.
Alex
http://www.northamericanmotoring.com/gallery/data/500/nam_moderator_16k.gif
email is best - alex@tirerack.com
If you order online, please reference "Alex 294" as your previous contact.
Check out my Blog: Alex's automotive performance guide
Old 03-14-2009, 09:47 AM
Dan00Hawk's Avatar
Dan00Hawk Dan00Hawk is offline
Gallery
Quote:
It's gonna be in the 50's here in Chicago today, and I'll probably be wearing shorts and a t-shirt when I go for a run later...
2004 MCS. PW/B. 16" Rota Slipstreams, 1 Ball Exhaust, Drilled Stock Airbox w/ K&N panel filter. 14.95 @ 93.8 mph
2000 Firehawk Convertible. Pewter, 6 speed. 12.52 @ 114.7 mph.
Old 03-14-2009, 09:56 AM
nabeshin's Avatar
nabeshin nabeshin is offline
Functioning Lunatic
Gallery
Garage
Quote:
I had the same thoughts. I'm looking forward to the 50º weather this weekend - I'm going biking
9/29/2002 EB/W MCS Broken - temporarily retired
Original owner since 2002.
Old 03-15-2009, 01:29 PM
minihune's Avatar
minihune minihune is offline
Moderating in Moderation
Gallery
Quote:
50 is freezing? Maybe for some but in Hawaii it's time for a jacket if it's in the 50s.
Follow what Alex recommends is best. Check tire pressure and don't be afraid of cold pressures about 34 or 35. If it stays really cold then a little higher is also fine.
If it really warms up then check pressure again if needed. Most owners don't check pressures enough and often will run low. A little high is better than too low. Sunlight does heat up the tires so checking early in the morning is a good practice.
http://www.northamericanmotoring.com/forums/sigtemp/SigLJ0z2K.jpg
#43 Street Modified (SM) Class SCCA Hawaii Region
2005-2009 Solo Run Off and Points Champion (Hawaii)(2nd 2006 Points)
2005-2008 Overall PAX: 8th 2006, 7th 2007, Tied 10th 2008.
2010-2011 Modified FWD RallyCross (Points Champion)
http://www.sccahawaii.org/pics2008/s.../img_38944.jpg
Old 03-15-2009, 02:14 PM
Gallery
Hey, where I live, summers average over 105 with little rainfall. Worse, it's better if it doesn't rain because a quick storm only makes it extremely humid. At least you don't have to live in a place where the temperatures change on a very wide scale. It could snow (yep, it did about a month and a half ago). Even then, I don't forget heat waves overnight, you know! I don't have a good immune system and it's VERY easy for me to catch a cold. If I catch a cold, it seems like 99% of the people around me are in better health than me. I even get sick indoors when they crank down the a/c in shopping malls in the summer.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
