Resetting Brake Pad Sensor Light - How?
Old 12-21-2011, 02:10 PM
schmuelkof's Avatar
schmuelkof
schmuelkof is offline
I have read these posts. None specifically answers. I have a 2007 MINI S (hardtop). The "brake" light was on. I had front and rear pads and rotors replaced, as well as the sensors replaced, front and rear. Mechanic who did work, did not reset. The "brake" light is still on. It is a "keyless" ignition. Can someone give me clear, simple English step by step procedure to reset it? Thank you in advance.
  #27
Old 12-22-2011, 04:32 AM
yetti96's Avatar
yetti96
yetti96 is offline
Keep on searching, it is there....
Here's a freebie
http://bit.ly/vf5XvG
https://www.northamericanmotoring.co...procedure.html
  #28
Old 12-23-2011, 07:35 AM
clutchless's Avatar
clutchless
clutchless is offline
You do not need to hold both buttons on the dashboard as indicated on the link. Just hold the right one down, when the brake sensor symbol appears (car on lift), then push the turn signal stalk end button to reset.
07-16-2020 12:54 PM
W0TM8
12-19-2019 07:50 AM
fjork_duf
Tires, Wheels, & Brakes
08-16-2015 04:38 PM
08-07-2015 08:02 AM
Quick Reply: Resetting Brake Pad Sensor Light - How?
