MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post I did it!!!
0 Replies, 3 Views
Advertisement
Thread Tools Search this Thread
Old 04-01-2007, 04:53 PM
macsbluemcs macsbluemcs is offline
Gallery
H&R Coilover Install
After tackling the rear sway bar and end link installation, My confidence is up to a coilover, control arm , camber plate install next .
My issue comes when I picked up a set of slightly used H&R coilovers and am looking to find some installation directions I contacted H&R and they sent me two unrelated files ...anyone out there have a set you could scan or point me in a better direction then I am currently heading.:impatient
Thanks ...
Macsbluemcs ...2006 MCS, Hyper Blue, White roof/stripes, Sport, Premium, HK sound, 16" Ultraleggera with Bridgestone S-03 Pole Positions, Whalen, Alta - CAI, 15% pulley, 2.5" Sportone, M7 - Strut Brace, Air Diverter, Aerogel EX, Magnecor wires, NGK - Iridium, H-Sport -19mm sway, Powergrid - end links, TSW - engine damper, Helix - lower control arms, LDG flash, Uber - CF Scoop.
Old 04-01-2007, 08:30 PM
qwertmonkey's Avatar
qwertmonkey qwertmonkey is offline
Send a message via AIM to qwertmonkey Send a message via MSN to qwertmonkey Send a message via Yahoo to qwertmonkey Send a message via Skype™ to qwertmonkey
Gallery
If they're fully assebled c/o, its a no-brainer. Just follow randy's how-to for the spring install, but instead of putting the stock strut back in with the new spring, replace it with the c/o. If you run into any snags, every one here is glad to help.
Good luck and congrats.
http://i156.photobucket.com/albums/t.../spiderman.gif
BLACK and Silver Hood Scoop GRILLES for SALE!!!
HERE!http://i66.photobucket.com/albums/h2...monkey/Sig.jpg
15% REDUCTION SUPERCHARGER PULLEY INSTALLED 11/18/2006!
22mm Rear Anti-sway bar installed!!! 3/25/07!!! Yay!!!
Old 04-01-2007, 08:31 PM
Gallery
Here's the link for the installation:
Spring install...
Old 04-01-2007, 08:39 PM
defylogik's Avatar
defylogik defylogik is offline
Send a message via AIM to defylogik
Gallery
This goes in line with the same topic, but the front bump stops when installed on a PSS9 or H&R setup, will these still work. from what i can tell from looking at these h&r coils sitting in my house ready to install the shaft is a LOT bigger on the h&r coils (bilstien strut) compared to the stock shaft.
Can anyone shine some light on what you use for the front bump stop on these???
SOLD - '05 MCS | PS/B | Premium & Cold Weather | Alta 15% | m7 Coilovers | Lookin Tuff on S-Lites | Miltek Catback | TxSpdWrx | H-Sport Rear Bar | Pilo Intake | Whalen | Aero Kit Bling - SOLD
___
'10 Cooper S Cabrio
Old 04-01-2007, 09:41 PM
k-huevo k-huevo is offline
Gallery
Here’s a how-to with working pictures http://www.northamericanmotoring.com...ad.php?t=92737 , The stock nuts are 21mm on front and 16mm on the rear’s, Bilstein’s are 22mm and 17mm respectively and the rears have a different thread pitch so use the nuts with their kit.
Bilstein has yet to respond to my question about bump stop usage but others have observed the spring will bound before the strut runs out of travel. I’m aware of the progressive nature of bump stops and the energy release from a bound spring but I don’t know if running bump stop-less on the MINI will be an issue.
Old 04-02-2007, 05:55 AM
defylogik's Avatar
Gallery
the strut will bind before it runs out of travel, which i confirmed by putting it upside down in the floor and leaning my weight into it untill it compressed all the way. i think another thing to keep in mind is that the "helper coils" will touch when progressive rates are installed, so that eliminates the chance completely of the top ever coming in contact with the actual shaft seals. who knows...
the rears compress pretty far though from what i can tell by hand compressing them.
___
'10 Cooper S Cabrio
Old 04-02-2007, 06:10 AM
defylogik's Avatar
Gallery
anyone with pss9s or h&r coils know what you use for bumpstops
___
'10 Cooper S Cabrio
Old 04-02-2007, 09:11 AM
AZMCS AZMCS is offline
Gallery
Quote:
nothing. 20k miles no problems. H&R does not use them.
'05 MCT JB/JB: Hubie Fuh designs Turbo conversion
'07 MkV VW GTI UG:The wife's toy
'08 Ducati 848: Just as big of a money pit I only use 8 months of the year....
Old 04-02-2007, 08:27 PM
sonichris sonichris is offline
Gallery
the fronts are bilsteins. all bilsteins have an internal bumpstop (they are actually upside down, the shaft and bumpstop are inside the lower part of the shock). so do NOT try to put a bumpstop on these. i don't know what kit you have, but on some the rears are not bilsteins (they have a skinny normal looking shaft). these do require bumpstops. the included document says to use your normal bumpstop without cutting. i lowered mine about 1.7 inches in the rear, so i did cut mine about in half. YMMV. HTH.
chris
03 MCS | comptech header | milltek exhaust | alta 15% | wms 2% crank | MTH std file | H&R RSS Club Sport coilovers | IE adj camber plates | alta psrs | steve's adj rr ctrl arms | no front swaybar | homebrew CAI | homebrew catch can | defi d-gauge boost | aero grill | R56 front calipers and rotors | EBC yellow stuff | ATE super blue | 225/45/16 bfg kdw2 | flik ftd 16X7 ET42 |
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
