MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Welcome to North American Motoring, the North American MINI Community of owners and enthusiasts!
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and photo galleries. By joining our free community you will have access to post topics, communicate privately with other MINI enthusiasts (PM), respond to polls, upload your own photo gallery and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact our support team.
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Not a member? Register now!
Welcome to North American Motoring !
» Main Menu
Upgrade Garage
» Latest Main Topics
My first Cooper S
My New Camden S!
burning mustard colored oily...
Some Questions
IF YOUR CAR FEELS SLUGGISH...
Official Hot Chocolate Owners...
Ahhhhh clutch problems
SUCCESS! Rear view mirror...
205/40/17
Not So Good Vibrations
Advertisement
Vendor
 Aftermarket vendors
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 02-27-2007, 10:08 PM
COR BLMY's Avatar
COR BLMY COR BLMY is offline
Gallery
BC coilovers installed (how-to & feedback)
I have installed the new BC (BR series) coilovers.
here is a short how-to with photos of the units and the install.
The BR series are 30 way adjustable compression / rebound adjustable.
Have ride height adjustability both Front and Rear.
AND come with adjustable front camber plates.
All 3 of these features were what I was looking for in doing a upgrade.
An additional feature is flexable adjuster extensions for the rears that I wanted to install to be able to use the adjustability feature WITHOUT having to remove the unit or even lay on the ground
These coilovers are well known in other market applications.
HERE THEY ARE...(as delivered)
Tools and extenders included
Here is a short HOW-TO
Again I installed to be able to adjust from above. They can be set and then installed, but to then adjust the rears they would need to be partially removed to reach the knob on the TOP of the rear.
The main point of the install is to show the MODIFICATIONS needed to do the install.
Jack up the vehicle and use jack stands
NOW to remove the fronts ... then do all the install
TIME TO INSTALL
I jacked up the rear so as to be sure that in the normal position AND under load the adjuster clears the hole. As the suspension works the top does move.
... about stock height.
My final setting is 1+" lower then this.
I set the rear were I wanted it THEN adjusted the front.
The ride height would be about stock with thr front set here.
Final shot of panel reinstalled and the flexable adjuster on.
This is about a "straight shot" up from the coilover.
I was going to put at the "cubbie" door in the back but the more than 90 deg. bend...
just didn't feel quite right.
I could feel the indent position but not as "clearly" as the straight position.
MORE photos to come of vehicle shots as soon as weather permits.
I have now had the coilovers on for just 2 days (the car will be having a full alignment and corner balancing this weekend).
My first impressions are GREAT !
Firm and good road feel.
Still trying different settings on the compression / rebound.
The adjustment stiffens up the compression.
OR adjusting the other way softens compression.
You can feel the difference.
I started in the middle (setting 15) and today reset to 5 and could feel the softer ride.
The springs are stiff... they feel stiffer then the H sport (with stock shocks ) that were on before.
When ALL adjustmenta are made I will put them through more testing and adjusting.
All in all the quality looks good and the features are great.
The price point is excelent.
Camber plates, shocks and springs OR camberplates and coilovers elsewhere are more $.
Nice to see other manufacturers and vendors supporting the MINI crowd.
We now have more choices.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
KW V1 Coilovers Installed. Vincent. Suspension 37 09-29-2009 05:24 PM
How many have installed their own coilovers? MiniBAH Suspension 14 08-05-2008 12:40 PM
Thoughts or feedback on BC coilovers ... ? COR BLMY Suspension 45 02-24-2007 12:43 AM
Feedback on Bilstein PSS9 coilovers? Morefun Suspension 2 08-31-2004 06:33 AM
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
Search Engine Friendly URLs by vBSEO 3.2.0
