Suspension R50 Coilovers question. Any help appreciated!
Hello all! I should get my coilovers for my R50 in a couple days. A couple questions: This is my DD, I hear that aftermarket camber plates are not absolutely necessary for a street dd. Is that correct? Can I get away with just the stock type plates (replaced 20k ago)? Another question, I am running 215/45/17 on bbs's (not sure offset). I am wanting to go down at least lip of well to tire and maybe a bit lower. Do I need spacers for that not to rub? I have seen such mixed answers on that one. Some don't need spacers, some need 5mm etc, etc. I also plan on getting rear adjustable control arms for camber in a few weeks but don't mind the negative camber until then. Tires will be replaced next month as well. I am just trying to get all of my ducks in a row so install will go smooth. All help very very appreciated!!
Thanks a lot for the reply. So it is ok (will work) for now to have just the coilovers in the front, right? I will be adding camber plates soon, but just for good measure and more to work with. How about for the rear? I am running a 215/45/17 on I believe a 9" wheel at the moment. When I lower the coilovers the rear will automatically camber in quite a bit itself, correct? Without adjustable C-arms (which I also plan on getting withen a couple weeks)
Very nice ride, man. And sounds good. I get my tires at cost and can get a set of 205/40/17s for 200 bucks. That's my main thing, is how low can I go on my 215/45s without adjustable arms or camber plates. So I guess I'll just keep my 45s on there to see if they rub first. Hopefully there won't be a problem since its a 7.5" wheel.
whosurgaddy
08-29-2015 09:50 AM
Bea5tMa5ter
08-27-2015 01:42 PM
ClayTaylorNC
08-10-2015 09:19 PM
