Suspension Koni FSD installed
Another KONI FSD install
I just installed KONI FSD struts on my 2012 MCS yesterday, and replaced my NM springs with my stock Sport Suspension springs.
So far, I'm really enjoying the changes. Highway expansion joints are basically erased, and it still "feels like a MINI" handling wise. Alive and responsive.
With two in the car, I was getting bump stop contact a bit too often on some of the county roads around here with the NMs. I have a favorite "torture test" stretch of road of frost-heaved concrete that was 20mph speed limit for me before. Ran it at 45 mph yesterday, no problem. Still wouldn't try drinking coffee through there, but very impressive control and compliance.
Very happy with my changes.
mountainhorse (04-02-2020)
I installed mine too and after installation there's a clucking sounds coming from the passenger side, when I received the packages the metal part where the spring sits separated from the tube and wondering if that causing the noise. control arm bushing was replaced a year ago and checked linkage for tightness they all good, during the installation I noticed that the strut top mount camber plate bearing has a slight wear (loose when shakes side to side) since I don't have a replacement (st---d I only bought driver side due to mushrooming).
Comments are greatly appreciated.
Awesome!
Today, I put my auction find 2006 Cooper S with JCW kit into front service mode, and removed the subframe. So much oil on everything! Tomorrow, I'll separate and clean the subframe. If there is still time, I'll install Powerflex front control arm bushings, inner ball joints, Powerflex steering rack bushing, Powerflex sway bar bushings, and new power steering hoses.
I'll need to order outer ball joints, outer tie rod ends and CV axle grease for sure... but I'll hold off for my next order until I get further along. My local Mini shop is way too pricey, and shipping to Canada is adding up quickly. (Ah, the joy of living in the sticks...)
- Darcy
- Darcy
The following 2 users liked this post by jcolletteiii:
bugeye1031 (03-11-2022),
Serafin (02-25-2021)
The following 4 users liked this post by Uber Commuter:
Got my K- Brace in ! here's a how to https://www.northamericanmotoring.co...ceinstall.html if anyone is interested. its a very tight fit.
i did a write up on how to here https://www.northamericanmotoring.co...ceinstall.html
The following 4 users liked this post by FakeName:
Driver-side window regulator and motor replacement. Not too difficult but the nylon gears that hold the window to the regulator can be a pain to remove and you have to be really careful not to damage the glass. ModMini has an excellent video on YouTube however he does not show you how to replace just the motor, only the regulator. When replacing the motor on the existing regulator you have to be very, very careful to ensure that the cable wheel/carrier does not pop out of its housing. If that happens, you'll be replacing the regulator. Don't ask me how I know. Since you're already in there be smart and just buy the regulator/motor in one piece and install the whole thing - would be MUCH easier!
I am looking to replace my shocks all the way around and I'm curious whether I should go with a coilover setup (Bilstein B14) or the red KONI FSD with my stock springs. For context it is a 2013 MCS JCW and I live in Miami (Coral Gables). It's important to me that the ride be as comfortable as possible while maintaining handling characteristics. Appreciate the input.
It's a fantastic setup for me - progressive when having fun, way less harsh in normal driving around.
The following 2 users liked this post by e24mpwr:
jetsr6 (02-11-2022),
mountainhorse (10-22-2021)
