Suspension Koni Yellows and springs just installed, front is higher than the rear
Hey gang, I just had Koni Yellows and Koni springs installed and it's lower in the back than I thought they would be. The front is higher than the rear. The shop said it would take a few weeks to settle in. I would have thought the weight of the front end with the engine and trans would settle in the front but it's been a week and the front is still higher than the back.
Is there a way to correct this so that the car is level and/or the back is higher than the front?
The front springs are bigger and stiffer than the rears and do take some time to settle but check to be sure that the front springs are correctly positioned in their perches. Where are you measuring? Try taking height measurements underneath from level ground to the front and rear jacking points to be sure.
squawSkiBum
10-02-2015 09:21 AM
dyeLucky
08-07-2015 07:10 AM
