Suspension Looking to improve the ride quality
I am looking to improve the ride of my 12 Countryman S. I hate the bump steer and rough ride over bumps and joints in the road. When the road is smooth so is the ride but when it's rough....its rough. I'm not looking to make it into a go cart since its my daily driver and I sometimes have clients with me. I don't mind to drop it if the new springs and shocks will give me what I want. I know there are a few spring choices and only 1 shock option and then megan coilovers. Thats probably what my budget will allow. The question is which products should I get to get the best ride?
Here again with this issue.
Best 'handling' mod for the buck: KONI FSD struts and a heavier rear sway bar. Best resource is Way Motor Works. They have the KONIs on sale for a little less than half price. They work just fine with OEM springs but can not be used with lowering springs. For that you want the Yellows. But, before all that, ditch the runflats.
For the last 4 seasons I've been running 19" NM Eng. RSe14 with Conti3 tires for the summer...but it's still a tough ride on the bumps, heaves and crappy roads of CT. Highways and smooth roads can't beat the ride. Seriously thinking on downsizing to 18's...hoping that will improve things....not sure though. Time for new tires...so this would be the time. Either that or get into a much smoother ride for a vehicle for the old guys bones.
getting rid of runflats is like loosing a full rim size...but doing a 1 inch minus on the rim size, AND regular tires WILL change the ride and keep much of the handling....not all...but pretty good compared to other cars...
I think new springs helped with the bump steer. Also, I found out that these cars are set with a toe out alignment which helps turn in but also causes the car to get pulled around by every little thing in the road. Doesnt bother me, I'll take the turn in benefits, but maybe you could change the alignment.
I shouldn't but I will...
This reminds me of a true story . Guy bought a brand new Jeep on a Friday and Took it four wheeling over the weekend. Monday he shows up at the dealership, the Jeep is covered in Mud and the owner is complaining of rattles and wind noise from the soft top.
I've owned 4 Mini's and many others in my 40 yrs plus of driving. For better or worse they are Sports cars\sedans\coupes. Short wheel based engineered for sport driving and handling. They have never been advertised as anything else. Changing out the runflats for a set of non runflat tires with decent sidewalls ( meaning 16 or 17 inch tires not 18-20's) is the most you can do. If you try and soften the ride or change the alignment you wont then like the handling and may make the car dangerous.
I understand what you all are saying since this is not my first MINI. However, on my R56 I changed to NM springs and Koni yellows and got better handling with a MUCH improved ride. Yes MINI's are sporty cars and aren't intended to ride like a Cadillac, but if there is a way to get rid of some of the bump steer and the harshness at broken pavement and expansion joints I'd like to know.
Shane Wendel
R60 :: Countryman Talk (2010-2015)
09-18-2015 06:18 PM
