Suspension KW V1 Coilover Setup.
Ok, I just picked up a set of KW V1's off the market place here. I've done some searching through the forums and have ideas on what to do with the coilovers. But I wanted to also check on other mounts and things needed to do a full seasonal swap each year.
I'm still trying to decide what I want to do for camber plates. And I think I am going to go with the Helix rear control arms so I can adjust rear camber appropriately. But I wanted to find out what other mounts and plates I need to make this a full swap over come winter time when I go back to stock shocks. Do I need the spring plates or pads? Do I need the protection tube?
Basically I just want to remove the bolts and be able to swap to stock without taking the coilovers apart and I just need to get the required parts.
Also, I've seen come conflicting information on adjustable swaybar links. Do I need them? I've seen some people say they dont need them at all, others say they couldn't install the coilovers at all without them. I'm assuming it depends on the coilover, but I wanted to check with everyone.
I bought a set of adjustable rear control arms, but never installed them. Ran the whole last season at the highest front / matching rear KWv3 setting, and got even tire wear front and back (-2.2 degrees camber up front) after ~10 autoX events (~10 runs each) and daily driving.
Don't forget to do an alignment !
Good luck,
a
You basically need four sets of fully assembled coil-over suspensions to bolt in-out. That means extra set of camber plates for the front (adjustable are a good idea, Hotchkis and Vorshlag works great, and are rebuildable). Also an extra set of upper shock mounts for the rears (I went OEM).
Yes sir! I see above you're running -2.2 camber up front so that sounds good. I assume without adjustable rear arms, the rear alignment can't be adjusted?
Thanks!
If you are installing an adjustable height suspension (coil overs), you technically should have at least one adjustable swaybar drop link per axle to prevent pre-loading the swaybar. Be sure to choose a drop link that has a high quality bearing in it and that it's booted (covered with a rubber boot). There are a couple of brands that have cheapy, sloppy heim joints which make your suspension clatter mercilessly.
Rears were set accordingly, to keep the car as close to level as possible.
In practice, unless you are competing for money, it's irrelevant. If you ever drive with passengers or less than full tank of fuel, your pre-loading is out the window.
I literally didn't touch a thing in the rear.
I had bought lifetime alignment (useful for seasonal swaps), and was planning to go back to for the rears once I learned how far off they were. After adjusting the fronts (did all 3: camber, caster, and toe), the rear toe was good, negative camber was high, but I never went back to do anything about it and the tire wear worked out perfectly for me.
YMMV,
a
Gen 2 ECS MINI 4x100 Spacers are here: 3-20mm with the bolts ( black ) . So you can get the right wheel / brake / suspension fitment for your needs.
http://www.ecstuning.com/News/MINI_R...013_2014_2015/
The stupid bolt is of self-tapping variety, threaded into aluminium trailing arm. The arm's threads have enough life for 3-6 re-tightening cycles to 100+ ft.lbs, then they strip.
For replacement, I bought 3" (or was 3.5", I forgot, search archived posts) 10.9 grade bolts, nuts, and washers from:
https://www.boltdepot.com/Metric_hex...0.9_steel.aspx
a
If I was swapping out rear suspension on a friend's MINI, I would (personally) have a replacement set ready to go, just in case.
Search the archives, and you will find my pics, story, and specs (length, etc) for the replacement bolts and washers. I had also looked into helicoils and other ways to repair the existing threads in the aluminum trailing arm, but then realized that bolt+nut approach would be far easier. I've had those 10.9 grade bolts on the car for the last year+, swapped rear c/o's with them at least 3 times, no issues to report.
YMMV,
a
sssevita
03-20-2016 06:24 AM
