Suspension What Camber Plates?
Vendor
Since your not lowering the car the fixed camber plates will work fine.
And yes they prevent mushrooming as they are about 3/16 thick rather than just the stamped steel of the stock ones.
http://www.waymotorworks.com/ireland...e-r50-r53.html
What are the thoughts on IE adjustable camber plates with the FSDs? The FSDs have already been ordered. I will be running stock springs and it is street driven with no plans of tracking the car. I MIGHT lower the car in a few years at which time I would go to a coil over and different springs of course. Do the adjustable plates cause any problems with the FSDs? I thought I read that the adjustment can't go past 2 degrees with stock springs. Being street driven do I need to go past that?
The FSD will be good for the street and stock springs. If just street driven I would suggest the IE Fixed Plates instead of adjustable plates because the adjustable will have a harsher ride. With the fixed plates you should end up with about -1.5 to -1.75 deg which is plenty for the street. Add a 19mm rear sway bar to the front camber plates to obtain a nice balance.
Front camber changes very little with lowering so there should not be an issue with fixed plates on the front.
Lowering greatly changes the rear camber and usually requires adjustable control arms to get camber to a reasonable amount. Of course the need for adjustable control arms this depends on the amount you lower and if you have an 05/06 with OEM camber adjustability.
The ST XTA Coilovers also have the camber plates on the front with them, so that another option.
http://www.ecstuning.com/Search/SiteSearch/ES2730623/
Yes, adjustable plates are much better for complete control of the front camber, especially
if you have a dual purpose car (track, ATX, daily driver). Everything is a compromise, however,
and for some people, a fixed camber mount is right for them. I considered it when I put Koni
Sports and a rear bar in last month, but wanted just a little less camber than the IE fixed plates,
and I didn't want to go for an adjustable plate, so I stayed with a stock shock mount for my daily driver.
Also, I think that people who slam their cars are a bit short sighted and get what they deserve.
Just wanted to chime in as I fixed a snapped bolt on my IE fixed plate this past weekend...
If you go with the Craven shock tower defenders you have to cut the bolts that are welded to the IE camber plates. The Craven defenders use a two bolt mounting system per stud and I found that the IE studs were too long to work with the combination bolt. I suspect that the play cause the bolt the snap/shear.
Anyways, I took a cutting wheel on my dremel and took 1/3" off each bolt and everything mounted up fine.
This is only an issue with the Craven defenders as the strut mount/camber plate bolts don't pass through like other anti-mushrooming plates.
IE Fixed camber plates
Howdy. I came across this thread while looking around the site. I used IE fixed camber plates on my R50 and have installed them on 3 other MINI's over the last 7 months. So far, every single one of them has come back complaining of snapping/popping sounds on mild bumps. We went through the installation meticulously and once we started taking these things off the cars, we noticed that every single one of them had sloppy bearings. A close inspection of the bearings revealed what we suspected.......Made in China! Don't get me wrong, the rest of the assembly is great! Very sturdy, but the most important wear part is a cheap piece of junk. Needless to say, we contacted the vendor, and even IE, no one will give us the time of day. We managed to get a person at IE who said that "we may have gotten a bad batch of bearings" but offered no resolution for 800 bucks worth of sloppy camber plates. A quick internet search showed that we are not alone in our problem with these fixed camber plates.
Interior/Exterior Chrome strip above license plate, who makes black ?
got_mini?
10-07-2015 02:12 PM
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:28 PM
10-01-2015 12:13 PM
