Suspension What is the best streetable coilover system?
I used racelands coilovers for multiple years on my wrx as a DD. only had 1 issue with the tophat bolt due to my fault over tightening. I called them up and within 2 days i had a new tophat.
most people hate on them in the subaru community since everyone there are elitist jerks but they rode fine and i wasnt tracking the car so for under 5 bones, why not?
I just installed a set of Bilstein PSS10. They are both ride height and rebound adjustable. Nice thing is that the dial for rebound adjustment is easily reached and can be done in seconds. Also you do reuse the spring top hat portions front and rear.
I don't believe the PSS10 will work on a Gen1 but the PSS9 do and they are similar.
"I don't believe the PSS10 will work on a Gen1 but the PSS9 do and they are similar."
We have the PSS10 for the gen 1 here and they are pretty.
http://www.ecstuning.com/News/MINI_Cooper_R50_R52_R53_Base_S_JCW_Bilstein_PSS10_ Coilovers_2002_2003_2004_2005_2006_2007_2008/
We have the Gen 1 ST X and the ST XTA = XTA if you want the front camber plates.
Some of your decision is going to be based on how much money do you plan to spend? You can get out for $750 or so or spend over $3000...
Answering my own question again from personal experience:
Modding the ST coil overs with linear springs up front and ditching the progressive rate springs that they come with in favor of a set of their more softer springs is the trick but you would be better served by something that has linear springs in another higher end kit from a cost perspective.
ST XTA also have the font camber plates now, which is a plus.
molala
10-02-2015 01:53 PM
09-04-2015 02:34 PM
M7Speed
R60 :: Countryman Talk (2010-2015)
09-04-2015 10:47 AM
