Suspension Countryman on Megan Coilovers
Old 11-26-2012, 04:16 AM
Roy75's Avatar
Roy75
Roy75 is offline
Am currently on eibach lowering spring.. I would say it a good match but I wanna slam it down more with coils..
  #27
Old 11-26-2012, 10:11 AM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
FYI we have 4 sets of the specific Megan Racing R60 coilovers in stock:
http://www.waymotorworks.com/megan-r...ountryman.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
  #28
Old 11-26-2012, 04:41 PM
Roy75's Avatar
Roy75
Roy75 is offline
Hi, can it fit a ALL4?
  #29
Old 11-26-2012, 04:42 PM
Shoe Coupe's Avatar
Shoe Coupe
Shoe Coupe is offline
nvm
  #30
Old 11-26-2012, 06:53 PM
Darna's Avatar
Darna
Darna is offline
Originally Posted by Roy75
Thanks for the clarification, just abit worried if it will be troublesome for adjusting the damping when whole shock need to come off? I cant rem if there is a opening at the rear boot..
It's a pain to adjust the rear because there is no opening at the rear boot, the whole strut would need to come off.
  #31
Old 11-26-2012, 06:58 PM
Roy75's Avatar
Roy75
Roy75 is offline
yar, I suspected too.. even the KW V3 I guess.. my worry now is most seller telling me its only for FWD.. I just wanna know why.. becos of the damping/spring rate? or mounting diff?
  #32
Old 11-26-2012, 06:59 PM
WayMotorWorks
Vendor
They will physically fit the ALL4, I think they would work fine, but Megan does not list them for the ALL4. Just the opposite the KW coilovers that actually work on both, but KW only list them for the ALL4
I've found over the years most customers never adjust the rears they just set them in the middle and are good to go. You could drill the holes and use remote adjusters if you really get serious, but you have to pull the interior panels to do it. I personally just pull them out to adjust as they are only 3 bolt each to adjust.
  #33
Old 11-26-2012, 07:06 PM
Roy75's Avatar
Roy75
Roy75 is offline
[QUOTE=WayMotorWorks;3631988]They will physically fit the ALL4, I think they would work fine, but Megan does not list them for the ALL4. Just the opposite the KW coilovers that actually work on both, but KW only list them for the ALL4
Yup, I realised it too on the KW listing stated only ALL4.. thanks for the clarification..
  #34
Old 11-29-2012, 10:09 AM
frstrtdmac's Avatar
frstrtdmac
frstrtdmac is offline
No all4s availability yet huh?? Meaning, if I put these on an all4s what would happen?
  #35
Old 11-30-2012, 11:00 AM
Shoe Coupe's Avatar
Shoe Coupe
nothing, it would most likely fit fine and give you no issues.
  #36
Old 12-28-2012, 10:30 AM
Shoe Coupe's Avatar
Shoe Coupe
To the OP, how do you like the ride so far? After some time driving it?
  #37
Old 12-28-2012, 12:21 PM
SmithWerks's Avatar
SmithWerks
SmithWerks is offline
for those not mounting a matching set (ie FWD to ALL4 & vice versa), 'Some' manufacturers may not warranty the part if it was equipped to a vehicle not listed.
(ie FWD kit on an ALL4).
I know Bilstein is pretty particular about this & often askes for VIN/Reg when processing warranty claims. (no match, no warranty).
I'm nopt saying its the case w/ either manufacturer listed in this thread.. however, it is a reality to think about.
  #38
Old 05-31-2013, 03:52 PM
Pierre-Olivier Cloutier's Avatar
Pierre-Olivier Cloutier is offline
Any review afetr a couple of months?
I can't decide if I try the Megan Racing coilover or not...
  #39
Old 05-31-2013, 04:01 PM
Shoe Coupe's Avatar
Shoe Coupe
Yup. Ive had mine on since January, been about 4500 miles. Not a single issue, no popping, no creaking. I even put the car up to double check to see if the collar nuts are tight, they still are.
No issues at all, rides like it came from the factory this way.
highly recommended.
  #40
Old 05-31-2013, 09:14 PM
Good to ear!
My CM will look great with this and my gold OZ Alleggerita 17x8.5 ET35
  #41
Old 05-31-2013, 10:19 PM
smallhabitat's Avatar
smallhabitat
smallhabitat is offline
highly recommended.
I agree! I only have about 1000 miles on them and the ride is like night and day. It's a completely different car now and would definitely recommend the Megans to anyone thinking about lowering their CM.
  #42
Old 06-18-2013, 07:48 PM
borderwave2's Avatar
borderwave2
borderwave2 is offline
highly recommended.
What did you have to buy in addition to the coil-overs? Front/Rear End Links etc?
  #43
Old 06-18-2013, 09:50 PM
manho1dup's Avatar
manho1dup
manho1dup is offline
Get a pair of lower control arms to adjust camber and alignment for the rear.
  #44
Old 06-19-2013, 06:56 AM
WayMotorWorks
Vendor
Like he said you'll want a set of Hsport rear camber links to keep from eating through your rear tires.
  #45
Old 06-20-2013, 05:50 AM
chini's Avatar
chini
chini is offline
Any reduction in bump steer with the Megan's?
  #46
Old 06-20-2013, 01:06 PM
manho1dup's Avatar
manho1dup
I got a pair of the the H-Sport LCA's from Way and they are really nice. Great quality & construction. Also, Way ships really fast, came in 2 days from day of ordering. Thanks, Way!
  #47
Old 06-23-2013, 05:40 PM
thegingerwagon's Avatar
thegingerwagon
thegingerwagon is offline
Does anyone know how to get to the rear shock towers on the countryman??
  #48
Old 06-24-2013, 09:09 AM
MotoGreg's Avatar
MotoGreg
MotoGreg is offline
Unlike most cars, you don't access the top of the rear struts from the top/inside the car. On the MINI they use two bolts that go up, through the strut top mount and thread into the body. So you access them from under the car, not inside the car.
  #49
Old 06-24-2013, 12:15 PM
thegingerwagon
Thanks! I eventually figured it out, but now for some. Reason my rear suspension sounds a bit rattly when i go over large bumps so thats the problem im facing now
  #50
Old 07-12-2013, 05:52 AM
chini's Avatar
chini
chini is offline
Anyone? Bueller? Anyone?
Quick Reply: Suspension Countryman on Megan Coilovers
