Suspension OHLINS installed on the R56 !!
Old 08-27-2016, 09:56 AM
whrisk's Avatar
whrisk
whrisk is offline
Does any one know if the R56 Ohlins kit will fit an R53 if you leave off the cone piece for the bottom mount in the rear?
I have a kit for sale and the person has an R53. I don't want to sell him something that's not going to work.
  #252
Old 08-27-2016, 11:32 PM
squawSkiBum's Avatar
squawSkiBum
squawSkiBum is offline
Moderator
Your prospective buyer needs to compare the specs for the R53 and R56 kits carefully.
R56 is BMS MI20. http://www.roadandtrackbyohlins.com/...I_BMSMI201.pdf
R53 is BMS MI10. http://www.roadandtrackbyohlins.com/...I_BMSMI101.pdf
Rear spring rates are the same and overall height is the same, but I don't know if it will fit properly.
Fronts the R56 has 70N/mm spring vs. 60N/mm for the R53. Other than the spring rate difference it is hard to tell if the dimensions work out to be the same because the R53 is shown with the Ohlins top mount vs. the standard top mount. Assuming it fits, the spring rate difference would be a concern for me. Al
  #253
Old 09-01-2016, 07:46 AM
Fengest's Avatar
Fengest
Fengest is offline
Problems with Ohlins BMS MI20
Hi everyone,
I recently installed a set of Ohlins Dfv with eibach TOP mounts, I encounter creaking noise whenever I turn the steering wheels to its maximum. Can some of you guys advise.
Thank you
  #254
Old 01-17-2017, 06:57 PM
edwkmho's Avatar
edwkmho
edwkmho is offline
Hey Guys,
I had my Ohlins DFV installed for almost a year now. Undeniable good quality coil over.
Last week i went over a pot hole and my strut tower seems to mushroom slightly, and the top mount (guide support) has hairline crack. Do you guys think it is a good idea to install the strut tower plate?
One last question, has anyone tried to repair strut tower mushroom, need advise on the repair.
Thanks.
  #255
Old 06-01-2017, 01:46 PM
oldcracker's Avatar
oldcracker
oldcracker is offline
Has anyone ran different springs with the Ohlins? If so, which ones specifically?
  #256
Old 06-01-2017, 02:02 PM
JPMM's Avatar
JPMM
JPMM is offline
You would probably have to go to Ohlins to ask that question, and to source out the springs to make sure they are compatible.
  #257
Old 06-01-2017, 02:23 PM
ridinDirty's Avatar
ridinDirty
ridinDirty is offline
I think in this post a guy named rafrantic (something like that)!had tried a few different springs , prob 2 years ago ....
  #258
Old 09-29-2017, 12:03 PM
John_theCapn's Avatar
John_theCapn
John_theCapn is offline
On my R53 setup, I tried a set of Swift 7kg/mm front, 5kg/mm rears.
I essentially went back to the Eibachs that came with the kit. (6F/5R)
Did it work? Yes. Did I notice a change? Yes. The front-end response was more pronounced. Why did I change back? I felt it changed the car a little more than I expected.
Edit: I should note that this may have been a result of lots of experimenting with different susp parts at the time (about 6-7 years ago).
adrchn
08-13-2019 02:11 AM
squawSkiBum
10-02-2015 09:21 AM
JPMM
08-13-2015 12:01 PM
Mini Cooper r56 Pr
08-12-2015 07:42 PM
Quick Reply: Suspension OHLINS installed on the R56 !!
