Suspension Strut Bar
#26
#30
Umm, not exactly.The concept of a strut bar is intended on reducing the flex between the front strut towers during hard cornering loads. By reducing this flex, it allows suspension points to remain undisturbed, allowing for the suspension to do it's job properly. This often gives the drive a feeling of increased stability and improved turning response, when in reality, the suspension is reacting as designed. When a strut tower deflects it affects the camber of your front wheels which in turn affects the amount of rubber you have on the ground.
#31
exactly. It PREVENTS(actually reduces) DEFLECTION, as I stated.
They 'help' reduce/eliminate additional/unwanted chassis flex(deflection), therefore 'helping' to maintain proper camber.
If you lower your car, you will gain camber & increase bump steer. Getting a proper alignment will get you back within 'spec' as long as you are not excessively lowering the car beyond the limits correctable via factory parts.
Factory parts have limitations on how much correction can be achieved. *Aftermarket parts aid in levels +/- adjustments. (ie camber bolts, pillow ball mounts, adjustable control arms, tie rods, etc)
#33
I'd like to know this too
Kyle
[edit] It does fit Found this picture in the beginning of the thread that "minicmsall4" had in their gallery - https://www.northamericanmotoring.com/gallery/showphoto.php/photo/102739/ppuser/101182
#34
My only concern is that the STB mounts to the shock tower with no protection for the shock tower mushrooming effect. I'm sure everyone will say "that's never going to happen on the CM", but guess what, that's what they said about the R55/R56 when it was notorious to happen on the previous gen. Both of my shock towers mushroomed from the nasty roads I drive every day. Better to be safe than sorry, I'd rather have a STB that offers additional bracing to help protect the top of the tower from mushrooming to happen again. Are there any others that do this for the R60?
#35
#36
#38
It's structurally a weak area that mini has addressed but it still a concern/issue.
(roads, run flats, wheel wt/tire size, etc all seem to effect it) See the poll thread.
Strut bars will help reduce chassis flex/maintain correct camber but do not really reinforce the mounting area that is generally 'weak'.
It appears there are a few vendors that have metal plate that mount underneath the metal(strut area) to strengthen/disperse the impact/load & prolong/reduce/eliminate the damaging 'mushroom' damage.
#41
Has anyone checked to see if strut tower reinforcement plates for a different model MINI (like these) will fit the R60? The hole pattern certainly seems similar from the pictures....
#42
#44
#45
#46
I just ordered the VIP strut bar and have a garage lined up to install it for $70. But I know it's really easy, I just don't have the tools. Can someone advice on what tools I need please? Maybe cheaper to just buy and DIY?
#47
Keep your $70 and buy a set of combination wrenches, not sure of the size it was but it takes like 10 minutes to install. If your handy at all or have a friend who is its easy. Just tighten the bolts down nice and tight. Get your dealer to torque them for you if you wish. Just go in and ask them to do it. If they are worth their salt a tech will come out to the parking lot with a torque wrench and check them for ya....30 seconds of his time.
#48
#50
