Suspension Negative Front Camber Increase
I was able to initially obtain close to one degree negative camber in front on my 2010 Justa by removing the plastic pins. However, after adding Bilstein HD struts and M7 strut top plates, I lost almost half a degree of that.
This is a street only car and I am just looking to get the front to 1 and 1/2 degees negative. It looks to me that one should be able to acheive this by simply elongating (grinding) the holes inboard in the strut towers that the strut studs fit through,and machining the holes in the M7 plates to allow them to be moved inboard.
I understand camber plates may be needed for more extreme negative camber settings, but I am puzzled why I have not read anything about simply elongating the holes.
Appreciate your input.
DOC
DOC
ebowling
90
08-04-2019 09:15 AM
Minibeagle
08-13-2015 10:00 AM
ClayTaylorNC
08-10-2015 09:19 PM
