MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post MINI's on TV!!!
133 Replies, 4,428 Views
Advertisement
Thread Tools Search this Thread
Old 03-11-2010, 08:42 PM
laxpimp6903 laxpimp6903 is offline
Gallery
Coilovers: Do i need rear lower control arms
I know that when you lower a mini using lowering springs, it is necessary to install rear adjustable lower control arms to keep tire wear even. Is this the same when using coilovers since they function differently and are not just simply a shorter springs?
Old 03-11-2010, 08:55 PM
WayMotorWorks WayMotorWorks is online now
Vendor
Gallery
Garage
Yes you'll need rear lower control arms. Get a set of the Hsport rear camber links, they are the best. That way you'll be able to get your alignment straight.
MINI OEM and Performance Parts, Service, Racing, ECU Tuning,and Repair
Owner of the Texas Speedwerks Company
Old 03-15-2010, 10:30 AM
RedSkunk RedSkunk is offline
Send a message via AIM to RedSkunk
Gallery
It's dependent on how much you're lowering. The further you go, the more messed up the alignment and the more adjustability needed. The 05-06 cars have limited camber adjustability in the rear to begin with.
[ pics ] [ page ] 2006 HB/W MCS: 15% pulley, intake, full exhaust, 380cc injectors, RMW tune (201whp/191lbs tq), colder plugs, BC coilovers, 22mm rear sway, Alta PSRS bushings, rear control arms, R56 front brakes, Carbotech pads, TSW engine mount, Helix short shift, Outmotoring gauge faces, whizzeels, blah blah blah
Old 03-15-2010, 11:00 AM
ZippyNH ZippyNH is online now
Gallery
The change to the rear geomerty is still the same from what I know...as Way said...yes... Or spend$$$$ on lots of tires and get sub-optmal handling.
Old 03-15-2010, 11:01 AM
JohnnyVillan JohnnyVillan is offline
Gallery
Im slammed on coils and I dont have adjustable control arms. Most people here will disagree, but I like the camber. The only reason I want to get the control arms is so I can add more camber.
You can kinda see the camber here. I estimate it to be about -5º but I dont know for sure.
The fronts are an entire different story. I ended up with positive camber up front when I lowered my car (someone explain how thats even possible lol) so I NEED camber plates.
Old 03-15-2010, 02:32 PM
04indimcs's Avatar
04indimcs 04indimcs is offline
Gallery
I'd say your rear camber looks more like -3.5 to -4.
Old 03-15-2010, 05:13 PM
Gallery
I thought so too until my buddy (who's camber looked about the same as mine) got an alignment and he had -5º
I need an alignment lol
Old 03-15-2010, 07:27 PM
04indimcs's Avatar
Gallery
Haha have you not gotten one since you put the vmaxx on?
Think about it though, that means your 1 degree off from Rally when he's aired out. But, who really knows until you get the alignment done.
Old 03-17-2010, 09:11 PM
mrjasey mrjasey is offline
Gallery
id recommend getting the control arms so you can adjust your camber. you dont NEED to have them, but it will help conserve your tires
R53 PS/B
| daily driver | aerokit | + stuff | + more stuff to come | link to my progress | and my overweight GR STI |
Old 03-17-2010, 09:15 PM
Gallery
lol no I havent got one yet. The car doesnt pull much and I like the camber. I'll get around to it eventually. Im sure my toe is probably pretty far out and Im gonna destro my tires. Not that I really care cause I want smaller tires anyway lol.
Old 03-17-2010, 09:34 PM
MoxieMini MoxieMini is offline
Gallery
You don't really need control arms (as has already been said). Negative camber isn't really going to mess with your treadwear. It's the toe-in/toe-out that'll screw your tires up. If you're going super low and plan on tucking some tire, negative camber is your friend. I've probably got about -2.5 degrees or so (perhaps a little more) and without it my rear wouldn't be nearly as low (i.e., not tucked). I just did a rotation (after about 8k - 10k on my tires with the camber the way it is) and the tread looks completely normal.
Old 03-18-2010, 08:50 AM
Vendor
Gallery
Garage
WOW -2.5 and -5 degrees. You all crazy, that is way too much camber. On the racecar we don't run anywhere near that. Remember as the suspension travels if that is what you had at the alignment, you'll have even more when the spring compresses. Get the control arms and a good alignment, they will be cheaper than a set of tires.
Old 03-18-2010, 02:48 PM
Gallery
Yeah, for performance needs, it might a bit much. I'm only rockin' that much camber so I don't rub any more than necessary on my DD wheels/tires. Still, I haven't seen any abnormal wear on the tires with my toe aligned properly.
Old 03-18-2010, 04:01 PM
04indimcs's Avatar
Gallery
Quote:
Are you running 0 or 1/16" toe all around?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
