MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 11-11-2009, 12:01 PM
tazio tazio is offline
Gallery
IE Fixed Camber Plates: Longevity?
Thinking about refreshing my front suspension and weighing the option of going with OEM strut plates ($70) or IE Fixed plates ($180). Like the idea of dialing in a little more camber, but don't like the idea of having to replace/overhaul on a regular basis. I have about 110k on my original plates/bearings with no issues. Can I expect as much out of the IE units? I have heard of people having some major issues with them. Anyone out there with a lot of miles on the IEs? Real world data needed. Thanks!
Old 11-11-2009, 12:17 PM
IanF IanF is offline
Gallery
2 years so far... maybe 20K miles. No issues... no abnormal tire wear. Mostly a short hwy commute with occassional back-roads romps. A few auto-x events as well. From what I've read, the actually rubber mount is a heavier duty version of the OE mount (from a 3 series?) welded to a custom plate.
I've installed these on 3 cars (mainly in an attempt to prevent mushrooming). The only one that ran into trouble was when the car owner didn't heed the warnings to have the car aligned immediately (as after initial installation, the tires will be toed out a bit). He wore out his front tires PDQ as a result. One of the other cars has closer to 50K on them.
"Market research is bunk... the public don't know what they want, it is my job to tell them" - Sir Alec Issigonis
Old 11-11-2009, 12:56 PM
Gallery
Thanks Ian. Hoping to get more than 20k out of them, but that is a great data point. Good to know about the alignment.
Old 11-11-2009, 02:02 PM
andyroo andyroo is offline
Gallery
They'll certainly last longer than the OEM top mounts IMO. The major issues with IE plates, if i recall, is for the adjustable race plates only.
The design of the IE fixed plates is quite good. I've worked with many different top mounts for a variety of cars (and helped design a few) and the IE plates are a nice simple solution that looks very sturdy to me.
- Andrew
2005 BRG MCS
Old 11-11-2009, 03:45 PM
Crashton's Avatar
Crashton Crashton is offline
Gallery
33K on mine & they are holding up well. IMO these should last longer than the stock strut mounts, they are very beefy. You will love the benefits of the increased negative camber.
Old 11-11-2009, 08:00 PM
DanSeals DanSeals is offline
Gallery
I think it's a standard BMW bearing on IE's mounting plate. I have 25K of hard driving on mine with a couple of track days mixed in there. Still working perfectly.
Old 11-11-2009, 08:08 PM
Fatherdeth's Avatar
Fatherdeth Fatherdeth is offline
VILLAIN
Send a message via AIM to Fatherdeth Send a message via Skype™ to Fatherdeth
Gallery
Garage
I've been running mine since 2006 and approx. 32,000 miles and no problems. The bearings are replaceable. They are supposedly a little bit more heavy duty than the stock BMW ones are. That's good, as my car had a burnt out bearing at 17,000 miles before I went with the IE plates. Not to mention, you get some great protection from tower damage. I love mine and highly recommend them.
~Lilith~ 2005 MINI Cooper S **Enjoy Your New Home**
Old 11-11-2009, 10:33 PM
ej's Avatar
ej ej is offline
Gallery
IE fixed plates
Got about 10K miles on them with little over a year. No problems here. Have done multiple track days and couple autoX events.
2005 MCSa HB/HB, Alta CAI+silicone tube, 15% pulley, RMW cam, 4-1 header, Milltek catback, Brisk plugs, JCW injectors, Vitessepro tune, Alta IC diverter, H-Sport comp RSB, Powergrid rear endlinks, Koni yellows+springs (Sport kit), Megan RCAs, IE fixed camber plates, Carbotech Bobcat (front), Hawk HPS (rear), ss lines, 16x7 SSR type-C rims, m7 STRP, S2K antenna, Euroshelf
Old 11-12-2009, 05:02 AM
BlimeyCabrio BlimeyCabrio is offline
Gallery
About 30,000 miles on mine. I expect them to last "forever" the way they're built and the way they're holding up.
I'm Paul, The car is Blimey--- BlimeyCabrio's Blog--- 2006 MCSCa w/lotsa mods and Union Jacks
Ten-time Dragon Veteran - Occasional Trackrat - Extreme Twisty Addict - Rhymers Ferry Road Fanatic
Old 11-12-2009, 05:26 AM
THE ITCH THE ITCH is offline
Gallery
I have not heard of any failures with the fixed plates from I.E.. Any of the failures have been from the I.E. adjustables. The bearing used is from a BMW "Z" series which is a much heavier car. I do not believe that the bearings are replaceable in the fixed series. The plates are much beefier than stock and should have no problems out lasting the stock ones. As mentioned you will love the additional negative camber and the extra support from mushrooming.
Steve
Old 11-12-2009, 04:50 PM
Gallery
Thanks everyone. I will probably pull the trigger on these.
Old 11-14-2009, 02:23 PM
norm03s's Avatar
norm03s norm03s is offline
Gallery
I like mine.
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
George Carlin
You can follow me if you want but it might hurt.
Old 11-14-2009, 10:16 PM
davisflyer's Avatar
davisflyer davisflyer is offline
Gallery
Quote:
I've been thinking about getting these as well. Do you align the car to normal specs?
2006 CR/B MCS JCW, RMW (Newman) Cam and RMW Street Header, JCW Suspension, H&R 19mm rear anti-sway bar, IE fixed camber plates, Mason Engineering lower strut brace, Continental ExtremeContact DW Tires, Red interior, Chrome, HK, RMW Tune, 223 WHP / 200 WTQ
Old 11-15-2009, 05:51 AM
Gallery
Best setup with the IE plates is something like:
Front camber: whatever it is - not adjustable
Front toe: zero to 1/16" toe out
Rear camber: -1.2 to -1.5
Rear toe: zero to 1/16" toe in
If you have an adjustable rear bar, back off on it one hole for starters from whatever you were running previously (if you had it set on stiff).
Enjoy
Old 11-15-2009, 11:56 AM
heyduard's Avatar
heyduard heyduard is offline
Gallery
Quote:
isn't the oem price per unit? check out my gallery for side by side comparo pics of the oem mount and the fixed plate.
over 35k on the fixed plates here. and loving every bit of the increased negative camber! plus front tire wear is now even.
so +1 for the ie plates.
"Intellectually, I knew what to expect. Emotively, HOLY SH**!!!!!!!"
- A friend, after driving my stock (at the time) 05 MCS ;)
Old 11-18-2009, 09:00 AM
Gallery
Quote:
We had it aligned to std specs (1/16" toe-in, IIRC) with the understanding the camber would be out. We took the car to a shop that does track/auto-x alignments and corner balancing, so they did not have a problem doing what was asked. One friend took his car to a garage that wanted to align the car "to spec", which was obviously not possible with the IE plates, so do some research to find your shop before doing the work (if DIY) or find a shop to do the install & alignment that won't be phased with installing non-standard parts.
Another word of warning: if your car has some miles on it and you live in the 'salt belt' then the tie-rod ends may be seized and adjustment will be difficult. The first car I installed these on had over 100K miles on it and the tie-rods were so thoroughly frozen with rust, we had to replace both outer and inner rod ends.
Old 11-18-2009, 12:53 PM
AutoXCooper.com's Avatar
AutoXCooper.com AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
Gallery
That's a good word from IanF. Also note if the shop uses heat to break the tie rods free for adjustment, make sure they let them COOL on the alignment rack or the cooling down may pull the toe out of spec. I've seen it happen.
Old 11-24-2009, 07:16 AM
meb meb is offline
Gallery
IE fixed plates come with the Z4 strut bearing...still a BMW part.
FYI...adding more neg camber will increase toe in, not toe out. If the steering rack were in front of the axle centerline more neg camber would increase toe out.
Damn it Jim! I'm a doctor, not a scientist!
Puresilver 05 JCW Blackleather Anthracite BBS RGR Chrono Xenon Coldweather HarmonKardon iPod
Old 11-24-2009, 09:57 AM
Gallery
Yeah... I was wondering about that... the one friend who didn't get his car aligned right away experienced really bad inside wear... but wouldn't toe-in cause more outer wear?
Old 11-24-2009, 10:50 AM
Gallery
toe influences how much wear you get, not where it occurs. for the most part.
camber decides where the wear occurs.
- andrew
2005 BRG MCS
Old 11-24-2009, 12:52 PM
meb meb is offline
Gallery
But toe out and neg camber in sufficient amount will rip the inside of a tire apart ...I know you know that Andrew, just adding to the commentary.
- andrew
Old 11-24-2009, 01:34 PM
Gallery
correct.
- andrew
2005 BRG MCS
Old 11-25-2009, 07:37 AM
Gallery
so how does excessive toe-in cause inside wear?
Old 11-25-2009, 09:39 AM
Crashton's Avatar
Gallery
Because the tires are being pushed somewhat sideways. After I installed the IE plates I was amazed at how the front end pushed. The tires actually squealed at slow speed going around corners. Once the alignment was done all was well & everything became happy.
Don't try & skip the alignment part of the install.
Old 01-14-2010, 07:48 PM
jbkoopa's Avatar
jbkoopa jbkoopa is offline
Send a message via AIM to jbkoopa
Gallery
im getting these IE fixed plates
excited, cannot wait!
'03 R50 PS MC
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
