MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Swift vs H Sport
by putttn
0 Replies, 1 Views
Go to first new post R53 issues
12 Replies, 514 Views
Advertisement
Thread Tools Search this Thread
Old 09-21-2009, 08:45 PM
minIfrank minIfrank is offline
Gallery
mini cooper s lowering springs DIY HELP!
hello im just looking for someone in the NY/NJ area that could please install my h&r springs in my mini..i realy dont have 200 dollars to bring to a shop and i need this done by this saturday..thanks and let me know!
Old 09-23-2009, 07:02 AM
malteseracer malteseracer is offline
Gallery
I'm on Long Island. I'd definitely help you out if I'm not at school or work. I don't have load of experience, but if you just need another set of hands I don't mind. I will probably get the same springs eventually so I'll know how to do it.
2009 R56 PW/PW "Jeremy"...6 Speed, Sport, Cold, Hi-Fi, Piano Black, Stubby Antenna, Alta Intake, Alta Hot Side Boost Tube, Functional hood Scoop, Alta Exhaust, Alta Rear Endlinks, Scangauge II, Cooper Side Scuttles, 22mm Alta Rear Sway Bar, KW Variant 1 Coilovers, CravenSpeed Adjustable Short Shifter, NM-Engineering Torque Arm Insert, S.P.E.C. Stage 2.5 Clutch and Pressure Plate.
Old 09-23-2009, 09:24 AM
Splattj Splattj is offline
Gallery
Garage
Check out the DIY. With some basic hand tools and a jack you should be able to get it done.
http://www.northamericanmotoring.com...ll-how-to.html
Old 09-23-2009, 09:41 AM
iwashmycar's Avatar
iwashmycar iwashmycar is offline
Send a message via AIM to iwashmycar
Gallery
^^^ good DIY.
there are also PDFs on Alta's (i think) website as well as M7's... some might be for coils but its nearly identical
-Adam. 09' MCS - SOLD 5/2011
Old 09-23-2009, 09:50 AM
go_mini_go's Avatar
go_mini_go go_mini_go is offline
Send a message via Yahoo to go_mini_go
Gallery
Call your local autozone and borrow/rent a spring compressor. OR remove the struts from the car and have a local NAPA remove the old springs. IIRC, you may not need a spring compressor to reassemble if they are lowring springs.
2005 MCS Jet Black
Old 09-23-2009, 11:09 AM
Gallery
thanks alot guys..but that DIY looks so complicating..lol idk i might have to just bring it to a shop..idk if i can do this on my own..i did it for my civic..idk if its going to be the same tho..
Old 09-23-2009, 12:07 PM
go_mini_go's Avatar
Gallery
If you completed the job on a hunduh, the Mini is very similar!
You can do eet!
2005 MCS Jet Black
Old 09-23-2009, 12:12 PM
Oxybluecoop's Avatar
Oxybluecoop Oxybluecoop is offline
Send a message via MSN to Oxybluecoop
Gallery
Old 09-23-2009, 12:15 PM
Gallery
Garage
Quote:
"Renting" them is free at a lot of Auto Parts places. Basically they charge your card for the part and refund you when you return it. You don't need them to reassemble, especially if you have a second pair of hands.
It's about a 4-8 hour job DIY depending on tools, knowledge, and assistants.
I did mine, half in the rain, with a friend a couple weeks ago in 4 hours. An impact gun does speed things up on disassembly but it's not at all a requisite.
Go for it. You'll learn something!
Old 09-23-2009, 12:19 PM
ALTA_Jarid's Avatar
ALTA_Jarid ALTA_Jarid is offline
Gallery
You can do eet!
FOR SHO!! With another set of hands you should be able to complete the install without a prob! Just follow Adams instructions and you'll be golden!!
Jarid Perry : Online Sales/Marketing Manager
ALTA Performance™
503.693.1702
WWW.ALTAMINIPERFORMANCE.COM
FACEBOOKE-mailAIMTWITTER
CLICK HERE FOR WEEKLY SPECIALS
Old 09-23-2009, 12:22 PM
Gallery
Garage
Quote:
Originally Posted by OXYBLUECOOP View Post
Wow, it's generally a bad idea to use an impact gun on a strut/shock that you're going to re-use. If you spin the shaft too fast or for too long, it can damage the internal seals. Otherwise, the installation seems correct.
Old 09-26-2009, 06:47 AM
Gallery
thanks for all the help guys..me and my friend just finished it last night..took us about 4 hours. they look really good ..i also put new rims tires at the same time..but the only thing thats worrying me is my low tire pressure light came on and my service engine soon light came on as well..what do you guys think?
Old 09-26-2009, 09:21 AM
Gallery
Quote:
The tire pressure monitor can be reset from the the OBC button on the end of your turn signal lever. As for the CEL it probably has nothing to do with a coilover install. Stop by your Autozone and they'll pull the code for you.
Old 09-27-2009, 01:57 PM
jcauseyfd's Avatar
jcauseyfd jcauseyfd is offline
Gallery
Yeah, those lights can be very coincidental. I had mine come on during the drive home from getting new tires put on. Nothing to do with the tires (thermostat). Just happened to come up at that particular moment.
2008 MCS CR/W CROC #361
www.tarheelminis.org
www.totehmoon.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
