MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post I did it!!!
2 Replies, 61 Views
Advertisement
Thread Tools Search this Thread
Old 09-04-2009, 11:10 AM
Nazrin Nazrin is offline
Send a message via MSN to Nazrin
Gallery
Suspension & Brake Needs
Hi MA peeps,
Ive done almost all there is to do on the engine so now I need light to be shed on my Suspension & Braking Needs .
For your info, I dont track my car at all and costs/performance is a major factor in my decision (due to bloody shipping costs - im in Brunei Darussalam).
anyways here are my options so far:
Brakes
1. Ireland Engineering Big Brake conversion kit (Rear)
2. TSW Big Brake conversion kit (front)
3. R56 Brembo 4-pot kit (front & rear)
Suspension
1. Need bushing - but which ones to go for? Wishbone? steering rack?
2. Coilovers - Megan Racing Coilovers with Swift springs setup
~~~No Rest For The Wicked~~~
Old 09-04-2009, 05:02 PM
Some Guy's Avatar
Some Guy Some Guy is offline
Gallery
If you dont track your car you dont need big brakes, end of story. You can only stop as your tires can grip. If you want to decrease your stopping distnace get sticky rubber. If the rubber is so sticky that you are no longer able to lock up your brakes (unlikely) you can graduate to a more aggressive pad if you are cheap or if you are spendy get bigger brakes.
If you are going to do bushings just do them all at once.
'05 HB/B MCS.
With: LED lit scoop - DIY AUX cable - Angel Eye running lights - M7 STB - Air horn - Rally Lights -SVT Focus LSD - Poly Control arm bushings - IE fixed plates
UCONN FSAE Engine Systems Head '10-present
UCONN FSAE dyno testing and tuning lead '09-10: www.uconnracing.com
Follow UCONN FSAE on twitter: http://twitter.com/UCONNFSAE
Old 09-05-2009, 03:57 AM
Gallery
Thanks, but the brakes are more for bling, so I dont need anything over the top. Just brakes that are both fucntional and looks good...for cheap
Old 09-05-2009, 11:24 AM
MINIdriver85 MINIdriver85 is offline
Gallery
For the brakes, can I suggest you to look at the AP racing Big brake kit? I still have to install them but everyone I know that has them loves them.
For the suspension, I'd suggest first of all front and rear trailing arm bushings, they are the most important imho, and then add anyone you want. But if the roads aren't very good where you live, I would be careful with those, I have them and the car is considerably stiffer so on bad roads this might be annoying. As for the coilovers, are you set on the Megans? I would go for Bilstein PSS or KW V1, you don't need many settings if you don't track the car but these will provide height adjustment and they are top stuff (not that the Megans are bad, mind you...)
Old 09-05-2009, 11:33 AM
Gallery
Thanks for that...okay lets refresh:
- AP Racing - I would love these only if it were sub 1k thou
- All front and rear trailing arm bushings - yeap all set..gonna get the Superflex from UK
- Coilovers - I just want a lower stance without compromising confort so I guess the Megans will do...
Thanks for the input
anymore for anymore?
Old 09-05-2009, 01:42 PM
AutoXCooper.com's Avatar
AutoXCooper.com AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
Gallery
I want to address this "lower stance without compromising comfort" and start by saying it can't be done.
Comfort is a very subjective issue and anytime you lower a MINI you give some comfort due to the limited travel of the stock and aftermarket systems.
Tire size also plays as big if not bigger factor in the comfort issue. 18's on rubberbands is not comfort. 205/50 on 17's is a good ride with little wheel gap too. In the summer I run a 205/45-16 and in the winter a 205/55-16.
Old 09-05-2009, 01:54 PM
Gallery
Dustin...PM sent....
Old 09-05-2009, 08:20 PM
Ryephile Ryephile is offline
The Technophile
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
Gallery
Speak for your own lineup. The Megan, BC, and Cross have less overall stroke than stock. The V-Maxx and KW coilovers have the exact same overall stroke as stock at 5.5" front and 4.5" rear (damper stroke). They are also 1.6" shorter, so setting ride height at 1.6" lower than stock results in identical compression travel. They retain stock-ish ride quality by using similar spring rates and damping curves. The KWs are close to critically damped whereas the V-Maxx are a bit underdamped and give a more comfortable street ride than stock.
Cheers
Ryan
Old 09-08-2009, 03:59 PM
apexer apexer is offline
Gallery
Paint the calipers and get some slotted rotors = Cheap Bling
04 MCS,CR/W,Anthracite,P-BLeather,15% AltaPulley,+2%AltaCrank,MTH,AltaCAI,IK-22plugs,DT-TB,NologyWires,Alta Oil CC,Magnaflow,EBC Greens,Stoptech SS BrakeLines,Ate fluid,H-Sport Comp.Rear Bar,Kosie K-1 TS Wheels(17X7 in white)w/Star Spec Tires,Momo LeatherShiftKnob,Euro Shelf,Zaino. MMC#150 - CROC#48http://www.thompsonsmithdesign.com/w.../CROC-icon.JPG
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
