MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post tires
4 Replies, 145 Views
Advertisement
Thread Tools Search this Thread
Old 08-01-2009, 08:10 PM
mgwatson mgwatson is offline
Gallery
Rear end "Clunk" after installing 22mm Rear Sway Bar
Hey guys, I just finished installing an ALTA 22mm rear sway bar on my R53 and I'm noticing a pronouced "clunk" when going over bumps and putting pressure on the rear suspension. Any ideas what this could be? I tried adjusting the sway bar on all three adjustment points thinking it might be a clearance issue but its not that, nor is it a broken/bent endlink those are fine too. Any ideas?? Thanks!
Old 08-03-2009, 12:22 PM
GOTCURVES GOTCURVES is offline
Gallery
I had a similar problem as well and found that the end link was not properly set into place on the sway bar.
Life moves pretty fast...Driving a MINI..slows everything down but you!
Old 08-03-2009, 08:43 PM
00zero's Avatar
00zero 00zero is offline
Gallery
i had the same problem, tightened up the end links and it went away.
Alta intake, TSW damper and mount, Powerflex gearbox mount, BSH lower, 17%, Borla sport exhaust.
Dinan springs, Koni yellows, TSW x-brace, Ireland fixed, TSW control arms, Powerflex front control and trailing arm bushings.
Bobcats, Tyrol bushings, Way SS lines and ATE Blue
Old 08-05-2009, 11:43 AM
MINIGURU@WAY MOTOR WORKS MINIGURU@WAY MOTOR WORKS is offline
Vendor
Gallery
Check to make sure the endlinks are tight.
Also check the 13mm bolts that hold the brackets on the swaybar bushings. Otherwise you shouldn't have any noise.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
