MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Swift vs H Sport
by putttn
0 Replies, 1 Views
Go to first new post R53 issues
12 Replies, 514 Views
Advertisement
Thread Tools Search this Thread
Old 07-22-2009, 08:59 PM
etalj etalj is offline
Gallery
Should I weld in the set screws of PSRS?
Hi guys, just ordered a set of Alta PSRS for my JCW, just wondering if I should weld in the set screws, as I have been doing a lot of research, and some people have reported that this is a fix for the one problem the PSRS have ever had.
Also, are there any other install tips anyone has (apart from what caster setting to set it at)?
Are there many DIYs floating about? Couldn't find any!
Elie
Factory built 08/08 MINI JCW: JCW Aerokit, M7 C-Wing, Bilstein PSS10, Vorshlag camber plates, RennSport Racing Rear Upper and Lower Control Arms, Howerton Engineering HFS-3 w/ Race Tank, Whiteline 20mm RSB, RMW Tune, Dunlop Direzza Star Spec Z1, DoS CAI, Evolve FMIC, BSH OCC + Dual Boost Port, NM SSK, etalj-spec torque arm ;), Goodridge SS Brake Lines, Endless RF-650 fluid, Carbotech XP12s, ALTA PSRS, Powergrid adjustable endlinks, Challenge Decals
Old 07-23-2009, 08:43 AM
Bigshot Bigshot is offline
Gallery
Other than welding the set screws, just tack weld the ends to the sleeve. Much easier and it holds just fine.
Old 07-23-2009, 08:57 AM
Gallery
tack weld the ends of what exactly to the sleeve?
Also, is that instead of welding the set screws, or in addition to?
Old 07-23-2009, 09:06 AM
Gallery
Instead of......our club just leaves the screws out.
You tack weld the end of the control arm to the metal sleeve. The control arm shaft ends right at the end of the metal sleeve of the PSRS.
Have you read this thread?
http://www.northamericanmotoring.com...-bmw-tool.html
Old 07-23-2009, 09:46 AM
Gallery
no, but i will. thanks! i'll report after i have read it all
Old 07-23-2009, 09:48 AM
gnatster gnatster is offline
Gallery
Quote:
Elie
Complete step by step directions can be found here.
Old 07-23-2009, 09:55 AM
ALTA_Jarid's Avatar
ALTA_Jarid ALTA_Jarid is offline
Gallery
Welding is fine. We welded the ones on my GP in because alll the cool people in the PDX MINI club do it....so heck if your buddy jumps off the bridge.. If you don't have access to a welder the screws are just fine. MAKE SURE you tighten the three screws evenly and it isn't a bad idea to use red loctite to make sure they don't move again.
Jarid Perry : Online Sales/Marketing Manager
ALTA Performance™
503.693.1702
WWW.ALTAMINIPERFORMANCE.COM
FACEBOOKE-mailAIMTWITTER
CLICK HERE FOR WEEKLY SPECIALS
Old 07-23-2009, 08:24 PM
Gallery
Ok read it.
I also forgot to mention that I'm having a BMW mechanic friend of mine install it, and I live in australia, and I've already bought the PSRS, so I can't order them pre-installed into the bracket. Basically, I'm asking if there's anything beside what ALTA give you in the instructions that I should do.
I think I'll screw in the set screws, AND tack weld the ends/sleeves. Any other thoughts?
Old 07-23-2009, 09:18 PM
btwdriver btwdriver is offline
Gallery
+ on tack welding the ends and also installing the set screws. The first time I didn't tack weld them, just the set screws, and they were constantly loosening up after I installed my coilovers (stiffer suspension).
I got tired of tightening them up and dropped the sub frame again and had them tack welded. Take it from me, weld them the first time, it's kinda a pain in the butt to drop the sub frame.
'07 MCS LB/B, One or two stock parts left...
Old 07-24-2009, 10:32 AM
Gallery
Thanks for the input
So you tack-welded the screws as well as the sleeves?
Old 07-24-2009, 10:34 AM
Gallery
No, I tack welded the bushing to the control arm, but I also used red loctite on the set screws. After you have the bushing tack welded, I doubt the set screws do anything, it was just easy to do, so I installed them.
Old 07-24-2009, 09:50 PM
Gallery
Sweet. Thanks everyone, you've all been a great help!
Old 07-25-2009, 07:05 AM
Gallery
After re-reading my last post, I just wanted to clarify that it is the bushing sleeve that needs to be tack welded, not the actual bushing... I know that seems obvious to most, just wanted to be clear.
Old 07-28-2009, 09:51 AM
ALTA_Jarid's Avatar
Gallery
Etalj, did you get these installed? Inquiring minds want to know!
ALTA Performance™
503.693.1702
Old 07-28-2009, 09:33 PM
Gallery
hehe fear not, the second they get installed, I will report.
They haven't arrived yet (shipping O/S is not an easy thing). Should be ready sometime next week...
Old 07-28-2009, 09:40 PM
Gallery
Set screws?
Old 07-29-2009, 08:29 AM
Gallery
Old 04-05-2010, 08:52 PM
Gallery
Sorry to revive an old thread, but I just installed my PSRS.
However, the welder didn't work, so we had to install it with red loctite alone, and surprise surprise, the set screws came loose and the knocking/rattling ensued.
Can anyone who has taken the arm/bushing off and welded the arm onto the sleeve let me know how they went about it?
That is, did people who welded the PSRS in place disconnect the bushing carrier before welding? My mechanic said there's the distinct danger of overheating the bushing (and any grease inside). Should I fully remove the bushing carrier before welding, or do it as is?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
