MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Hot or Not (Fuses)
by oPossum
65 Replies, 17,518 Views
Go to first new post Problem coding FRM/FRM2
19 Replies, 598 Views
Go to first new post MINI's on TV!!!
134 Replies, 4,451 Views
Go to first new post Best FMIC
2 Replies, 77 Views
Advertisement
Thread Tools Search this Thread
Old 07-15-2009, 02:06 PM
andyroo andyroo is offline
Gallery
Evening out front camber, without camber plates?
Disclaimer: I have not even looked at the lower mounts on my new (to me) 2005 MCS.
I was wondering if anyone has developed a way to even out the front camber on the 1st gen Mini WITHOUT using camber plates to do so? IMO camber plates should be set the exact same way on each side, otherwise funky things happen to suspension geometry and the roll center. And i'm a sucker for a "perfect" alignment.
I also plan on going with IE fixed camber plates because i want the rubber and quality bearing and don't want more than 2 degrees of camber. I know my strut towers are at least a little deformed, so it's likely not even at the moment.
Since camber bolts are apparently not possible on the R53, that leaves slotting the lower mounts....anyone done this? Also there was some rumor the front subframe was "adjustable" in some way....any details?
Additonal side question: will the IE fixed plates "flatten" my already deformed strut towers or simply prevent any further deformation?
Thanks for the help!
- Andrew
2005 BRG MCS
Old 07-15-2009, 02:16 PM
AutoXCooper.com's Avatar
AutoXCooper.com AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
Gallery
Hello Andrew, The IE Fixed plates will NOT always, if ever, be the same side to side no matter what you do to the towers. They will also not "fix" the tower only help stop the deformation. A hammer and 2x4 will help get the towers flat again.
If you want a perfect alignment you will need adjustable plates. You can get the adjustables to most any setting you want by moving the bolts around on the top plate.
Welcome to the "give and take" of MINI ownership.
Old 07-15-2009, 09:41 PM
Gallery
Any details or a thread on the hammer + 2x4 method?
I'll probably be giving you a call next week for those IE plates.
- Andrew
2005 BRG MCS
Old 07-16-2009, 04:08 AM
howsoonisnow1985's Avatar
howsoonisnow1985 howsoonisnow1985 is offline
7th Gear
Gallery
Straighten Towers
INSTRUCTIONS SEE PIC BELOW:
2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15
BRG/W 2003 MINI Cooper S R.I.P. Sheila
Old 07-16-2009, 05:30 AM
Crashton's Avatar
Crashton Crashton is offline
Gallery
Dustin is right you will most likely end up with a slight variation L-R. On my car the IE fixed plates gave me 1.9-1.8. I see no issues with this. While not perfect it is much better than I had before the IE plate install.
Dustin, wow gotta hate that eye popping banner...
Old 07-16-2009, 07:51 AM
Gallery
nice pic. so i just go "whack em mole" in my parking lot....hmmmm. i guess i'll do this after i put the plates in.
I'd be happy with a .1 difference side to side.
- Andrew
2005 BRG MCS
Old 07-16-2009, 07:54 AM
BlimeyCabrio BlimeyCabrio is offline
Gallery
Your results may vary. I have about -1.9 on one side and about -1.6 on the other. Even that amount of difference is insignificant from a handling and tire wear perspective. Even on the track.
I'm Paul, The car is Blimey--- BlimeyCabrio's Blog--- 2006 MCSCa w/lotsa mods and Union Jacks
Ten-time Dragon Veteran - Occasional Trackrat - Extreme Twisty Addict - Rhymers Ferry Road Fanatic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
