MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Hot or Not (Fuses)
by oPossum
65 Replies, 17,518 Views
Go to first new post Problem coding FRM/FRM2
19 Replies, 598 Views
Go to first new post MINI's on TV!!!
134 Replies, 4,451 Views
Go to first new post Best FMIC
2 Replies, 77 Views
Advertisement
Thread Tools Search this Thread
Old 07-14-2009, 07:30 PM
jbell jbell is offline
Gallery
Megan racing, full suspension/coilover setup?
Im looking to drop the car, and maintain some comfortably.
I want the ability to change height.
The adjustment on the megan's are nice, and i've read some good things about them.
I want to do this right though- and get what i need before the install.
So far i've decided on:
-coilover kit
-Rear ADJ. Links
-knob extensions
-strut tower protectors (i should have them now, i know)
what end links do i need in the rear, upper, lower or both?
are there any other parts i will need to properly re-align afterward?
what length knob extensions should i order (110, 200 or 250mm)
Old 07-14-2009, 11:34 PM
rcantu rcantu is offline
Gallery
if you get megans they have camber plates that will protect your strut tower.
Old 07-15-2009, 10:49 AM
andyroo andyroo is offline
Gallery
Where i come from (subarus) Megans are not known for good ride quality. Too little travel, crappy springs, and crappy valving. I have no experience with them on a Mini, but i know they use the same exact dampers whenever they can.
- Andrew
Old 07-15-2009, 01:45 PM
meb meb is offline
Gallery
If Megan have changed their entire component list I know nothing about them...if the kits are the same as when they began selling these for Mini then the above reply is basically correct...and the second reply is not - sorry in a nice way. Although Megan pillow balls - upper perch/camber plate - is bullet proof, the lack of travel, poorly designed bumpstops and springs with potentially little travel will cause the suspension to become stick and the strut towers will deform.
Once past 300lb/in springs you should consider after market strut tower protection.
Again, Megan pillow ball is bullet proof but the rest of the kit is far from perfect.
Damn it Jim! I'm a doctor, not a scientist!
Puresilver 05 JCW Blackleather Anthracite BBS RGR Chrono Xenon Coldweather HarmonKardon iPod
Old 07-15-2009, 08:36 PM
Gallery
Quote:
- Andrew
I had megan street coilovers on my 90-something del sol.
they rode like ****.
however---- that was 5 years ago and they didn't have any camer or dampening adjustment.
Old 07-15-2009, 08:39 PM
Gallery
im stumped on my other options then.
i was hoping to spend around $1200 for everything.
my goals are:
-2"ish drop
-lack of bone jaring SLAMS. sticking with 17" wheels, stock tire profile.
-ability to realign correctly (rear lower tie bars, correct?)
i'd like to be able to adjust the height for winter. NJ is a ***** like that.
Any recommendations would be helpful. I've been researching so much... i just need some seasoned advice at this point.
Old 07-15-2009, 08:43 PM
Gallery
IMO a 2-inch drop on a mini is nuts and it's gonna be hard to get there with good ride quality. You just have to have the travel.
- Andrew
2005 BRG MCS
Old 07-15-2009, 08:48 PM
AutoXCooper.com's Avatar
AutoXCooper.com AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
Gallery
Theres only 3 inches of travel in the stock system. You start to lower a MINI and that travel is toast very fast. A 2 inch drop on a street MINI for daily driving is not something I'd encourage anyone to do.
If "wheel gap" is driving the desire to lower the MINI I'd lower it an inch or maybe 1.5 if the roads are like glass, then get bigger/taller tires on the wheels to fill in the gap.
That will reduce the wheel gap without killing your spine. IMHO
I'll say in CO's like most things in life, you get what you pay for, and the Megan's are a good BUDGET system. If you want killer CO's save your money a few more months and get a set of Cross or think about the TSW KW's. But even then for a street MINI you are better off getting taller tires too.
Old 07-15-2009, 08:57 PM
Gallery
Hrm.
I can't say i understand suspensions too well. Its my worst subject next to transmissions.
Preload confuses me. It raises ride height, but increases shock travel?
I was under the assumption that if you cranked the coil up, and then the bottom collar over the entire sleeve you could essentially "lower" the car without reducing shock travel. This is how i had my del sol lowered- with no preload though.
Ok, so lets reduce my drop to 1.5 and keep talking....
Old 07-17-2009, 06:23 AM
meb meb is offline
Gallery
That is true with Megan and CROSS - lowering without sacrificing travel. however, Megan used the wrong springs and bumpstops in their kits. The springs were too short, and, no one paid much attention the spring's block height - when the spring compresses completely all of the coils touch. Every spring has a block height measurement. Block height must match suspension travel for a given spring rate.
Then, the bumpstops were too long. The mini is a bumpstop active car. The stock bumpstops are always in contact with the top of the shocks. But these bumpstops are called multi-cellular jounce dampeners. They essentially add spring rate to the minis suspension stroke progressively as the stroke nears the limits of its travel. If an old fashioned bumpstop of the same length is inserted in its place, the suspension will contact the bumpstop after about 1" of travel and in a turn the result is an immediate slide. When hitting bumps, the strut towers deform.
So even though the suspension has the capability to be lowered with affecting damper travel, the springs and bumpstops prevent this system from working well.
Stick with CROSS or go with another suggestion above...or Swift and Koni...
Old 07-17-2009, 08:54 AM
Gallery
The thing about coilovers that lower the car without sacrificing travel....they generally have hardly any travel to begin with. It works if you're running really high spring rates where bump travel isn't as important, but at that point you won't want to run it on the street.
JRZ, Moton, AST, KW competition, the motorsports level of coilover are not dual height adjustable BUT generally have a ton of travel in comparison. And they run a shorter shock body. So yes, lowering the car on a coilover like that reduces bump travel, but for ride heights you should be at, you still have a lot.
For Jbell i would recommend KW V1 coilovers.
- Andrew
2005 BRG MCS
Old 07-18-2009, 07:10 PM
RatBlast's Avatar
RatBlast RatBlast is offline
Gallery
i run the megan v2 coilovers in my mini . the people that are talking about bump stop isues and wrong spring rate are referring to the first generation of megans that came out.
the new megans will lower your car only a inch and a half , the ride quality can be set soft . i find they are not extreme enough of a ride . it will flaten out your cornering just great.
i went and dropped my car beyond 2 inches , but it takes extra work on your part to get it down that low. the front will not drop more than a inch and a half unless you take out some of the spring preload . the rear can be done without loss of preload , but you take out the 3 adjuster nuts and bottom out the lower shock tube to the springs.
i think megan is working on a version 3 setup. they have gone from one extreme of being to low in generation 1 to not low enough in generation 2 .
my new toy -------------- 1975 vtec mini :)
rmw head , rmw cam ,alta exhaust , obx header , 15% pully , 550cc injectors ,rmw tune , cia ,alta 22mm rear sway bar , megan racing coilovers .
lowered over 3" , clutch master fx400 and light weight flywheel , cusco LSD
Old 07-20-2009, 03:25 PM
Professor Professor is online now
Gallery
I love my Megans to no end. I did however replace the front spring in the V3's I picked up.
Old 07-21-2009, 01:09 AM
crazyaboutmini's Avatar
crazyaboutmini crazyaboutmini is offline
Send a message via AIM to crazyaboutmini
Gallery
i picked up a brand new set of megans earlier this year and replaced the springs with swifts... best setup i had or experienced. mine is set right around the middle because canyon carving is part of my daily drive and it works well. i don't mind the ride, i'm just really careful when i'm on s.f roads, but my cousin says its riding nicer than his gti with kw ver. 1's....
"... we need a ferrari, no two ferraris powersliding around a bentley that is also powersliding." - Jeremy Clarkson
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
