MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Show us your mods!
by ADAM244
19 Replies, 1,174 Views
Advertisement
Thread Tools Search this Thread
Old 07-11-2009, 11:46 AM
Noodle Noodle is offline
Gallery
Installing Rear Sway Bar
I got a smokin deal on a 19mm H&R swaybar. It is not as adjustable as some of the others out there. It only has two holes. I want to set it up on the stiffer of the two settings, am I correct in thinking that I should use the hole closest to the bend to make it stiffer?
Thanks for the help.
"Penfold"
Ordered 5/29 Landed in California 7/3. Delivered 7/19 08 MCS,
MCS Chilli Red, Black top & Mirrors, Bonnet stripes, Premium & Sport Packages, Xenon Lamps, MF Wheel. .
Old 07-11-2009, 01:10 PM
slinger688 slinger688 is offline
Gallery
Yes, toward the front is stiffer.
Old 07-11-2009, 02:37 PM
Gallery
Now I am using the instructions for the Alta 19mm bar for assembly and disassembly because I have never done this before. The instructions call out a 21mm bolt that holds the strut spring assembly on. My car appears to have a 19mm one. Am I looking at the wrong thing? Any idea on what the torque spec is on this?
"Penfold"
Old 07-11-2009, 02:48 PM
Gallery
Look at the better nm eng sway bar instructions with this link:
http://www.nm-eng.com/images/258856_ins.pdf
Old 07-11-2009, 05:01 PM
Gallery
Ok well I had other instructions from 2 other manufacturers. now I am having what I percieve to be a major issue. The other instructions did not say to only loosen the sub frame bolts on the left hand side of the car. I went to remove the center left one and some threads came along with. Major problem or just move forward?
"Penfold"
Old 07-11-2009, 06:15 PM
Gallery
The instructions posted work well. You have to loosen the subframe. It is easier to remove the old bar and install the new one if one side of the subframe was off and the other side loosened.
Any pics on the threads?
Old 07-11-2009, 06:24 PM
Gallery
I think I stripped the threads that are internal in the frame that the sub frame bolts to. Not good.
"Penfold"
Old 07-11-2009, 06:31 PM
Gallery
How many were stripped? Is it all the way or just a little?
Old 07-11-2009, 06:45 PM
Gallery
it is enough that I cant properly torque it. :(
"Penfold"
Old 07-11-2009, 06:54 PM
Gallery
You will need a tap and die kit to redo the threads for a more permanent solution. Any good mechanic can do this for you.
As a temp solution, you can reassemble with blue lock tight (non permanent) but do not over torque it.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
