Depends on the valving in the struts and shocks... If they're well matched to the spring rates, like ours, the ride will be as good or better than OEM even though the spring rates are higher...
For a quick and dirty calc, you can multiply by 5.7 to convert to lb/in:
FWIW, we normally spec similar rates in the front and the rear (e.g. like the HKS specs) and slightly firmer rates than any of those you listed for most dual-purpose street/track applications (6 kg/mm = roughly 342 lb/in for our KW V2s and 7 kg/mm = roughly 400 lb/in for our KW V3's).
I picked those 3 as they are available in my country (Malaysia). Of those 3, the Bilstein and Teins are rebuildable locally. The HKS either to Hong Kong or Singapore.
I will probably not go with the Teins as i do not favor the USD coil on the rear because its harder to access the adjustment knob.
So that leaves the HKS and the Bilsteins.
I think i might consider the KW, but i can't work out which of the 3 versions i should get. Do bear in mind my R56 is a daily driver but gets driven quite aggressively. Do you have any clue what the spring rates that come with the KW's?
The off-the-shelf KW's re-use the stock upper spring perch in the front and have a 'trapezoidal' shaped spring - we didn't test those, as we knew about what we wanted to start with (i.e. 60mm ID springs, our spec). We got our setups fine tuned at the track with the help of KW's engineers and trackside support.
The Variant 1 is ride height adjustable only. The Variant 2's offer damping adjustment (aka single adjustables) and ride height adjustment... The Variant 3's have independent damping and rebound adjustment (aka double adjustables) and ride height adjustment. I believe that the off-the-shelf units have fairly soft springs right out of the box... For most agressive street applications, I would recommend the Variant 2's - the Variant 3's really are overkill.
If local rebuilds are a priority, I would say that narrows your choices somewhat. I can check with KW and see if they have services available in your locale or near it if you would like...
