MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post I did it!!!
4 Replies, 61 Views
Go to first new post Best FMIC
0 Replies, 1 Views
Advertisement
Thread Tools Search this Thread
Old 05-06-2009, 12:15 AM
Doc Cooper's Avatar
Doc Cooper Doc Cooper is offline
Send a message via AIM to Doc Cooper
Gallery
Suspension setup help - fine tuning
This is my setup 08 MCS with factory limited slip
Cross Coilover - I cant go any lower on height
Helix rear control arm
H&R rear sway 19mm - set on stiff
Camber - front = -1.4 to -1.6 toe 0.10
rear = -1.8 toe 0.16
total toe is 0.21
i think i have to get more aggressive in the front.
I went to a local speed shop. I will not say their name. Located in socal. Pure POS experience... the guy didnt even know i had a camber plate in the front and tells me that he cannot make it more negative. I told him just forget it. I got ripped off...
When im doing a S curve, right - left or left-right transition just sucks.. car wobbles and leans too much.
Should I
1) Redo alignment - what settings do you guys recommend? I do spirited daily driving.
2) stiffen up the chasis come how and get rear strut or front strut?
3) better tires in 17 inch.. lower profile
i know stiffening the front will induce more understeer but the car feels not "planted"
Also, when im entering a turn, i have so much body roll (doesnt feel planted) and front tires grip too much and if i tab the gas, it wants to twitch.. does that make sense?
Please help
08 MCS: Astro/Rooster Red Manual - Cold PCk, Conv Pck, LSD- JCW AERO
CROSS Coilover | Helix Rear Lower Control Arm | H&R 19mm rear sways
Old 05-06-2009, 12:43 AM
scott48's Avatar
scott48 scott48 is offline
Gallery
aren't the shocks adjustable
ALTA: Turbo Back Exhaust, Intake, Intercooler, Boost Gauge, 22mm Rear Sway Bar, BOV...AccessPort?!
AEM: Water/Meth. Injection
Lots of Carbon Fiber...
Old 05-06-2009, 01:38 AM
Doc Cooper's Avatar
Gallery
Quote:
dampening yes.. out of 15, i set mine up at F10/R10 any more is too stiff on freeway.. hurts my back.. lol
Old 05-06-2009, 01:41 AM
Ryephile Ryephile is offline
The Technophile
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
Gallery
Your camber measurements are fine, but I'm not sure on the toe measurement: is that in degrees, inches, or what?
You have all the right hardware bits [except for decent springs i.e. Swift], but apparently your damper settings and coilover adjustments are severely out of whack. By "can't go lower" do you have any measurements of ride height [axle to wheel arch]? Going too low will induce understeer, but not instability. How are the coilovers setup in terms of spring pre-load and damper firmness?
I'm going to venture a guess that you need to bring it to a real suspension setup guru that's local. I'd be happy to help but distance is a hurdle.
also, FWIW, it's "damping", not "dampening". The latter is the process of getting something wet.
Old 05-06-2009, 01:53 AM
Doc Cooper's Avatar
Gallery
LOL my bad. oops.. dampening i meant..
When i say "cant go any lower", i meant in terms of height of the car.
Toe measurements are in degrees. So you think alignment is some what correct?
Im on 16inch oem wheels w 205/50/16 tires, i have 1.5x index finger gap with wheel arch and tires in the front. It isnt that low i dont think.
I wish someone can drive my car around and diagnose and fine tune... too bad you are far away.
Ill take my car to Danny @ MINICORSA here in socal and see what he says...
What "settings" do you recommend on the JIC Cross coilover?
Old 05-06-2009, 04:38 PM
dunphyj's Avatar
dunphyj dunphyj is offline
Send a message via AIM to dunphyj Send a message via Skype™ to dunphyj
Gallery
I currently run this setup on my mini... It's agresdive without destroying tread on the tires... I say it's worth a try, works just fine for me then I up my camber front to -3 and rear to -2 for track days...
Front -1.75 camber
-0.10 toe
Rear -1.75 camber
I hope that helps some...
0.20 toe
JP (the man) & Blue Bomber (the MINI)
LazerBlue R56 2007 What you see is whats installed... after all, with MINIs, "it ain't no 10 second race"... it's about bending the rules and ruling the bends!
Old 05-06-2009, 05:33 PM
Doc Cooper's Avatar
Gallery
Quote:
Front -1.75 camber
-0.10 toe
Rear -1.75 camber
0.20 toe
I think ill try to get more aggressive alignment..
thanks for the help.. i guess i just need to fine tune it alittle more..
what tires are you running? size?
Old 05-06-2009, 07:02 PM
dunphyj's Avatar
Gallery
Michelin pilot sport ps2 215/40-17
Old 05-06-2009, 08:47 PM
Doc Cooper's Avatar
Gallery
maybe thats the biggest difference... lol i have Goodyear F1 in 205/50/16 softer sidewalls... maybe ill setup my alignment to wear out my tires faster so that i can get 17s inch wheels/tires
So you guys think hardware is good and its just tuning my suspension?
Old 05-06-2009, 09:18 PM
COR BLMY's Avatar
COR BLMY COR BLMY is offline
Send a message via AIM to COR BLMY
Gallery
From now on change one thing at a time ...for fine tuning
Remember suspension is a compromise.
If you set up for on function you may be off elsewhere.
F1 sets up for the fastest corner and the slowest ...everything else is a compromise.
Here are some items to thing about.
Stock the MINI has quite a bit of rake (low front) many, when going to coilovers flatten the rake .. looks good but actually moves the ballance to the rear.
Stiffer springs may help. or try this (may seem backward) back off on the fronts ... go softer on your adjustment... this will help the front bite better.
You may also want to use the stiff rear bar at auto-x where you want the rear end to "come round" that may be to stiff for track / street
Sounds like you have good "bits"
Our 2 cars are different. For autocross and track we set one of our cars on 15" wheels and the other is on 17s. 17s arn't always best. Heck for Auto - x I would go to 13" if I could. 17s arn't going to fix a problem
fine tuning is where your at.
http://c3.ac-images.myspacecdn.com/i...b00c089576.jpg
Old 05-06-2009, 10:01 PM
Doc Cooper's Avatar
Gallery
Thanks for the info.
I know 17s arent the answer.. i was just trying to get better looking wheels for street use.. hahah
I do like your thoughts on the front.. im gonna go adjust it right now and test it out on the road... ill set it around 5 out of 15 and leave the rear at 13 and see how that feels..
I know i need a good alignment regardless.. need to take it to a alignment guru... know any in socal?
Old 05-07-2009, 11:53 AM
txwerks txwerks is offline
Vendor
Send a message via AIM to txwerks Send a message via Yahoo to txwerks
Gallery
Adjustable endlinks really, REALLY help in fast left-right and right-left transitions (especially slaloms), as you take preload out of the swaybars...
Old 05-07-2009, 01:50 PM
th3118 th3118 is offline
Coordinator :: Dynamic MiNi Collective
Gallery
Quote:
Really helped when I took off the preload off the sway bars. I think the Cross coilovers came with fronts, but I added the rear ones. Makes sense that as you adjust the coilovers up or down, you need to adjust the load on the bars.
Not easy adjusting them with the car on the ground, but it can be done. Easier on a lift that the wheels sit on it and you can get under it.
Old 05-07-2009, 09:43 PM
Doc Cooper's Avatar
Gallery
Some guys are suggesting that i raise my car just a tad bit to have more travel on the suspension. I dont think im that low. I measured it (the finger method ) and i have 2 finger gaps - index and middle)
Perhaps end links will help me.. im not sure if i have the fronts since i did not install the CROSS c/o myself. I dont think i got it (got it used with 1000 miles on it)
Im trying to go down to Minicorsa and discuss it with Danny. He's a track junky so he should give me few pointers..
Old 05-08-2009, 12:05 AM
COR BLMY's Avatar
Gallery
Don't listen to any of "the guys" who are suggesting that you "raise my car just a tad bit to have more travel on the suspension"
This is NOT how the coilovers that you have adjust.
Ride height adjustment moves the entire unit up or down in its lower mount.
Does NOTHING to travel !
If adjusting Pre Load that will have some effect on ride height and yes travel... But not the intended method of ride height adjustment or what you should do to set springs..
The adjustable END LINKS are part of your Anti Roll Bar ... not the coil overs (well they bolt to them) they would not come with coilovers unless purchased in addition.
Old 05-08-2009, 12:16 PM
Doc Cooper's Avatar
Gallery
i dont think its that low...
Old 05-08-2009, 01:25 PM
tedbone72P's Avatar
tedbone72P tedbone72P is offline
Gallery
Great thread! Lots of good info here. I don't have any suspenseion mods as of yet, but they will come in due time.
07 MCS "STEELER" Born 02/07 Mods to date: Helix FMIC, DDM Race Intake System, Exhaust depot ceramic coated catless downpipe, NM torque arm bushing, M7 SRP, Heat shield and Vortex Scoop, Forge Blow Off valve, DIY lower grill, Complete Black out, Joey Mod, WMW 4" stubby, Dunlop Direzza Sport Z1 Star specs, last but not least custom Steelers Rally Stripes, Emblems, Wheel center caps and steering wheel
Old 05-09-2009, 01:08 AM
danielo danielo is offline
Gallery
er... can you please elaborate on ths further please.
If the car is sitting flat, to me there isn't any pre-load/pre-tension on the ARBs....... to my understanding anyways.
And while in a corner, the pre-load is there which the th result of the ARB working......
I'm lost here.
http://i138.photobucket.com/albums/q273/jinkeong/danielo006.jpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
