MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post I did it!!!
2 Replies, 61 Views
Advertisement
Thread Tools Search this Thread
Old 03-06-2008, 02:20 PM
Vincent.'s Avatar
Vincent. Vincent. is offline
Gallery
KW V1 Coilovers Installed.
Hey everyone! I got a few requests for pictures of my suspension installed so here they are. I decided to go with KW Variant 1's because I just needed something a bit better than stock and to lower the car. I only plan on going to the track occasionally so I felt that I did not need a dampening adjustable setup. As for the ride, the handling has improved, I purchased my R56 with Sport suspension so I still have the sport sway bars installed. The comfort of the ride feels like stock but I know it will get better once I swap out my run flat tires. Please feel free to pm me with any questions regarding the KW coilovers.
As for my opinion, I love these coilovers. I am very happy with them but ran into an issue where a 5mm spacer had to be used in the front for clearance problems. I think this can be solved with a lower offset wheel.
Side View:
Front View
Front left (This is almost at the highest setting. There is plenty more space for lowering)
Rear left
Rear installed
2007 MCS. Dark Silver/Black. (SOLD!)
Old 03-06-2008, 02:24 PM
Rally@StanceDesign Rally@StanceDesign is offline
Vendor
Gallery
Nice Good pics.
Looks like they have the potential to go nice and low. That's good to see
Old 03-06-2008, 02:26 PM
Vincent.'s Avatar
Gallery
Quote:
Originally Posted by Rally@StanceDesign View Post
Nice Good pics.
Yeah...you can go really low if you want with these coilovers.
Old 03-06-2008, 04:43 PM
Ryephile Ryephile is offline
The Technophile
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
Gallery
Looks great! Where did you get them from?
Could you elaborate more on the handling and ride please? Does the car understeer more in corners or is the car more balanced? Is the ride similar to stock [standard or sport suspension] on both small bumps and huge craters?
Finally, are you using the stock lug bolts with the 5mm spacer, or did you find someone making longer 14x1.25 bolts?
Old 03-06-2008, 05:07 PM
Vincent.'s Avatar
Gallery
I purchased them from Status Auto Design in Hermosa Beach, California. The car has gained more balance through the corners, I can definitely take turns faster and the car feels much more solid. As for the ride, I was used to the Sport suspension because that is what my car came with so compared to that it is very similar in ride and comfort. Its not annoying or bumpy at all. And as for the lug bolts, they were able to get a set of longer lug bolts to accommodate the spacers. I plan on converting to TXwerks 14mm-12mmx1.5 studs in a couple weeks because the wheels I have coming have smaller bolt holes.
Old 03-06-2008, 07:15 PM
The Technophile
Gallery
Thanks for your insight!
Old 03-07-2008, 08:54 AM
Astro S Astro S is offline
Gallery
Look good! Thanks for the review of them as well.
I'm considering KW's myself but until now, I haven't heard much about them. It's nice to know the ride is good. I've been on those LA Freeways
How much did you drop it? I plan on only lowering mine about 1". I would think your down 1 1/2" to 1 3/4".
2007 MCS AB/AB
Old 03-07-2008, 08:58 AM
minipete07 minipete07 is offline
Gallery
Sounds like the same as my M7, even the 5mm spacers in the front
new-2011 MCSa. Traded in->2007-DS-R56-S..PAW Tuned!..Rooster Red line interior..Alta Boost Gauge.LSD.Xenons.ALTA CBE..FORGE FMIC..M7 Boost tube..DIY-9" AEM Dry-flow filter.M7 coilovers..M7 FSB..H-Sport 19mm RWB.Eibach RLCA..Street-17x7.5" Rota Boost Flat Black w/Red lip..Hankook V12 215/45ZR17.5mm H&R wheel spacers up-front.Track17x7''[COLOR=black] Enkei RP02.Hankook RS-2 215/45ZR17.Carbotech XP-10 Pads.StopTech Slotted rotors..S/S lines
Old 03-07-2008, 09:09 AM
heyduard's Avatar
heyduard heyduard is offline
Gallery
Hi Vincent! Thanks for being a test subject! Your Mini's looking very sharp!
Any picture of the front install whilst the Mini is on the ground? I'm curious to see how many working coils are available. Or a description would be fine.
"Intellectually, I knew what to expect. Emotively, HOLY SH**!!!!!!!"
- A friend, after driving my stock (at the time) 05 MCS ;)
Old 03-07-2008, 11:53 AM
Vincent.'s Avatar
Gallery
Sorry but I don't have pics of the front coilovers yet. I want to snap some soon to give everyone a better idea. The best I can describe it is while you look at the rear pics, the adjustments look almost half way down, based on that, the front looks to be adjusted about a quarter of the way down. Hope this helps.
Old 03-07-2008, 04:21 PM
Ben-Ja-Min Ben-Ja-Min is offline
Send a message via MSN to Ben-Ja-Min
Gallery
Didn't KW develop the suspension for the R56 Challenge car? Hence why they have the full set of V1, V2 and V3 available for the Clubman already, Challenge pace car used as a template.
Old 03-07-2008, 09:24 PM
VJD VJD is offline
Gallery
[quote=Vincent.;2080649]
Thank you for the report on the KW's. I'm considering getting KW V1's for my R56. Any guess as to what offset would allow the wheels to be installed minus any spacers? Do an alignment yet? If so, how far off were the settings from spec after the V1 install?
Old 03-07-2008, 10:58 PM
Vincent.'s Avatar
Gallery
[QUOTE=VJD;2083336]
When we were looking at the wheel clearance, it looks like you'll be safe with a 40 offset or less. I haven't got the chance to do an alignment because I'm waiting on my new wheels to come.
Old 03-08-2008, 08:37 AM
joe_r's Avatar
joe_r joe_r is offline
Gallery
On your KW coilovers,are the front springs as large as your factory front springs?
joe r
04 Mini S PureSilver/PureSilver.Aero kit,Sport package,Coldweather package,HK sound system,Lapis blue & Panther black leather.
Upgrades = Dinan Stage 5 ecu,Dinan boost upgrade kit,Dinan Intake,Dinan Throttle body,Invidia Exhaust,Dinan ignition wire set,Dinan rear sway bar,Dinan floor matts,H&R coilovers,Alta RCA's,M7 STRP's & BBS R90 wheels.
Old 03-08-2008, 09:07 AM
roofaS's Avatar
roofaS roofaS is offline
Gallery
Looks really nice
Stock suspension makes the car sit ridiculously high and looks very unsportinglikeish
2005 MCSa, Rays AM 18x7.5/5Zigen ZR520+ 18x7.5/Work VS-XX Burning Gold 18x7.5 et 45 fr/32 r, Parada Spec 2, Koni 1150 Coilovers, R56 Brembo's with 5mm spacers, Aero Kit fully color-coded, Bond Mini Front Bumper, CF Paddle Shifters with a/m OMP steering wheel, CraftSquare mirrors, Recaro Speed drivers seat, full Arqray exhaust system.
Old 03-08-2008, 07:43 PM
joe_r's Avatar
Gallery
Any updates?
joe r
Old 03-09-2008, 10:31 AM
Vincent.'s Avatar
Gallery
Quote:
joe r
The front springs are and shocks are about the same size as the KW coilovers. Its the front perches that do not clear depending on how low you want to go.
Old 03-09-2008, 10:33 AM
joe_r's Avatar
Gallery
So if you raise the front up will the spring perch be above the tire?
joe r
Old 03-10-2008, 07:30 PM
302_snake's Avatar
302_snake 302_snake is offline
Gallery
looks great, I'm looking about 1" drop. can they go higher?
Is the ride really similar to sport?
Is the front vibration reported on HR present?
Old 03-10-2008, 07:52 PM
JCW56's Avatar
JCW56 JCW56 is offline
Gallery
Hi Vincent,
Nice job. I have identical KW's on my car but was able to get around having to use a spacer for the front wheels. I have the identical original setup of sport suspension so its good to hear somebody elase has gone the same way. I went with the KW's because thats what they use on the Mini's in the challenge Cup (interesting not JCW).
I have 18" Wheels with a 35mm profile tyre. I originally had 17" wheels on with 40mm profile road slicks, but these are my track tyres now. The 17" were no problems at all it was only when i went top the 18" wheels it got tight. I had gone for 40mm profiles on the 18"s but there was NO WAY they work without spacers. I was sitting way lower on the 17" wheels as well and that became a hassle with some of the roads and driveways here in Aus.
I look forward to see what you do with Wheels and tyres.
JCW Tuning Kit, 17" Wheels, LSD, DSC, 20mm Rear Sway bar, Sunroof, KW Coilovers, Wilwood 4 pot callipers, Rear Slotted rotors, Forge BOV, Ireland Engineering adj Camber Plates, Alta Intercooler, Alta Turbo Inlet Hose, Boost Tube Uprade, Bespoke CAI System, JCW Turbo, Rear Mini Challenge Diffusers, Stealth GTT cat.
Old 03-10-2008, 07:55 PM
joe_r's Avatar
Gallery
Quote:
Originally Posted by JCW56 View Post
Hi Vincent,
Does your car wobble or virbrate when you take off from a dead stop or going thru the gears?
joe r
Old 03-10-2008, 08:57 PM
Vincent.'s Avatar
Gallery
joe r
No vibration for now...I don't think I lowered the car that much to cause any vibration, or maybe I just got lucky. I plan on adjusting them to sit lower once my new wheels come in about a month or so. (4 month wait on Volk wheels!!)
Old 03-10-2008, 10:00 PM
joe_r's Avatar
Gallery
Jeez it will be winter time by then,lol
DO you have any pics of the way yoru Mini Sits now?
I realy like your factory wheels.
joe r
Old 03-10-2008, 10:15 PM
Vincent.'s Avatar
Gallery
joe r
My R56 sits exactly like the pictures I posted. I haven't made any changes yet until the new wheels come.
Old 03-10-2008, 10:32 PM
joe_r's Avatar
Gallery
Rock on.
joe r
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
