MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
38 Replies, 850 Views
Go to first new post NM Engineering torque arm...
103 Replies, 9,298 Views
Go to first new post Head Unit Upgrade
11 Replies, 1,714 Views
Advertisement
Thread Tools Search this Thread
Old 01-22-2008, 01:06 PM
pimpedout97x's Avatar
pimpedout97x pimpedout97x is offline
Send a message via AIM to pimpedout97x
Gallery
What to do about ALOT of extra weight in the rear?
ok first off, i dont really know much about suspension for this type of stuff, other than airbag susension and that type of stuff for mini trucks etc...
anyways, when all is said and done with my system, as most of you know, the box (i think weighing in now around 130lbs) the sub (62lbs) the amps (about 40-60lbs in amps lol) plus batteries (im replacing the stock battery with a bigger one, that will add like 20 lbs more than the stock battery) plus a possible 2nd batt.....and 16 6.5s and 16 tweets (i know the tweets all together are 20lbs total)
most of that will be in the rear, so i probably dont need anything in the front, but the rear is deffinently going to sag im pretty sure.
also, im stock 04 jcw suspension, no aftermarket lowering springs or coils or anything so....i want to know what i have to do to address this issue before that time comes that its all installed.
also, any other issues you may see need to be addressed, deffinently let me know.
2004 Mini Cooper S JCW
6 18s....4 rims and 2 subs
Old 01-22-2008, 01:08 PM
glnr13 glnr13 is offline
Send a message via AIM to glnr13
Gallery
stiffer front sway bar to help tone down the possible oversteer and a set of coilovers to balance out the height issues
http://www.northamericanmotoring.com/gallery/data/500/newsig07.jpg
Old 01-22-2008, 01:21 PM
flyboy2160 flyboy2160 is offline
Gallery
add A LOT of weight up front so it also sags. then it will look slammed.
Old 01-22-2008, 01:41 PM
cristo's Avatar
cristo cristo is offline
Gallery
Garage
Take all the gold bars out of the back (Italian Job) and you'll be fine.
Cristo .... and his trusty BRG/BRG MC Bliksem
MMC #186
Old 01-22-2008, 01:53 PM
ChrisMCS04's Avatar
ChrisMCS04 ChrisMCS04 is offline
Peace Keeper
Send a message via AIM to ChrisMCS04
Gallery
+ to what glnr13 said.
And make sure to talk with someone about spring rates. You can swap out springs and put in some really heavy ones instead...
Example, go buy yourself a set of Megans and replace the springs with some Swift Springs that are 9kg or more because of the weight, and up front you will have to figure out a bunch of math or have someone help you that knows how to set up suspension. One thing is for sure, you will need to figure out how to get things dialed back in...You already know it is not going to be agile like it used to be.
Chris
Old 01-22-2008, 02:27 PM
Gallery
good points chris.
pimped- you could get stiffer lowering springs instead of going coilovers. i personally would just go coilovers for full height control. they make CO's without dampening control that are less expensive than say m7, pss9, or JICs
Old 01-22-2008, 05:09 PM
UKSUV UKSUV is offline
Gallery
Quote:
Originally Posted by glnr13 View Post
good points chris.
Indeed. The KV V1's are like $900. Or go with the K-Sports that Kalbone has. They are around that on the lower side.
WWW.TEAMHALFASS.NET
^ CEO/PRESIDENT/EL JEFE ^
Old 01-22-2008, 05:29 PM
Gallery
Quote:
yeah but you know it's all about the pss9's
Old 01-22-2008, 05:46 PM
22CooperS's Avatar
22CooperS 22CooperS is offline
Gallery
Quote:
It is an absolute CRIME to add this much weight to a JCW. If anything, strip the interior or keep the car as pristine and OEM as possible.
Sorry to be so negative, but really... you don't know what you're doing.
Dirty MINI in North East Ohio? Have it detailed professionally, using only the best products!
Visit my site for more information: yourcarclean.com
Old 01-22-2008, 05:49 PM
Gallery
you havent seen pimped's build up yet?! it's waaaaaaaaay past OEM/pristine
see here:
http://northamericanmotoring.com/for...d.php?t=121424
and here:
http://northamericanmotoring.com/for...d.php?t=114128
here's a flick midway thru the build of his speaker box:
Old 01-22-2008, 07:19 PM
CHILE_RED's Avatar
CHILE_RED CHILE_RED is offline
Gallery
WHY WOULD YOU DO THAT!!!!!!! HAHAHAH JUST KIDDING ALOT OF BASS IN A small car= HOTNESS!!!
P.S. I wouldnt do that to my car
2004 Indi Blue/White Cooper S.......M7 AGS V.3, 16% Supercharger pulley, strut tower brace, Hamann front splitter, MSD Super Conductor 8.5mm wires, Denso IK22's, One Ball exhaust w/ custom tips, B&M short shifter, Angel eye turn signals,COMING SOON: Custom tune, JCW 380cc injectors....
Old 01-22-2008, 07:23 PM
Dr Obnxs's Avatar
Dr Obnxs Dr Obnxs is offline
Vendor
Gallery
Hi Pimped!
Good to hear you're making progress.
Watch the market place for used coil-overs. Save some $ there. Then up the rear spring rate.
Do like others have said and actually work with someone who knows suspensions. The suspension is really easy to screw up and then you're effed for anything but cranking tunes when you're parked.
Matt
ps, find a place for the second alternator yet?
FES Auto= Worlds Best Shiftlight-Ian Cull Auto-Up-Auto Sportplus - R52 Top Commander
but wait, there's more! InvisiLens - Bav Tech SW - High Current Relay Module-
'02 CR/W S, Bunch of fun mods... '08 NFR/S Clubbie, close to bone-stock...
Dr Obnxs' Musings: a blog about cars, energy, technology and more....
Old 01-22-2008, 09:04 PM
Nitrominis's Avatar
Nitrominis Nitrominis is offline
Gallery
OMG does anyone read what the operating capasity of a mini is. The rear seat area was really designed to carry adults!!!! NO kinding!:impatient LOL Yes you are going to be a tad lower. Yes you can install a set of 9k Megan spring or other spring manufacture which should bring you back to level ride. This more then likely will not dramaticlly effect the way you are goinmg to drive your MINI anyway. But if you want a set of coil overs that work great and are cheap....MEGANS are work horses. PM BANNED at mini nuts . Or you can get a set of knuckles and install them in between the coils. (that one was for you Matt ... remeber the days.. LOL )
Old 01-22-2008, 10:25 PM
trackster trackster is offline
Gallery
Vogtland used to market a set of lowering springs for Minis with added audio. I dont know if they had as much in mind as you have in your car but it might be worth a call.
www.vogtlandsuspension.com
Old 01-22-2008, 11:02 PM
rkw rkw is offline
Gallery
Wouldn't more weight in the rear tend to increase understeer?
Old 01-22-2008, 11:05 PM
UKCoopeR's Avatar
UKCoopeR UKCoopeR is offline
Send a message via AIM to UKCoopeR
Gallery
think 911, though you might lose some turn in grip, ultimately more rear weight leads to oversteer
i think anyway, anyone confirm?
Mods: I have some. They make me :-) I am now broke :-(
Old 01-23-2008, 05:17 AM
Gallery
hit me up on AIM later today so i can talk to you more about this, but is there any specific sway bar you'd run inparticular?
Quote:
Quote:
i still havent seen that movie, i gotta watch it
good points chris.
damn $900 is alot... is that just for the rear, or all around? how much cheaper would springs be? pros/cons?
i can see where you're coming from, but im not into speed/performance as much, im way more into car audio, so thats why i went this route. its what i like.
see here:
and here:
hehe
hahaha
Matt
thanks, and no i havent yet, but i was talking to someone about it yesterday. i deffinently want to get it done in the future
Quote:
haha ya well my back seat carry's 4 amps and an 18" sub now!
cool, im going to look into that now while im at work.
what exactly does oversteer/understeer feel like? is it like when im pulling to a red light and my car will start jerking to a certain side, whichever the road makes the front tires go? or is that just becuase its fwd?
Old 01-23-2008, 05:27 AM
muladesigns1's Avatar
muladesigns1 muladesigns1 is offline
Send a message via MSN to muladesigns1
Gallery
sounds to me like you need to buy an SUV and leave the mini to the performance guys
I cant understand why anyone would destroy the interior of a mini to add cartoonish size speakers in it!
shaking head and slowly walking away
CF Hood,CF Hatch,17% pully, Borla Exhaust (-resonator), CAI, Hot Wires, HR 1.5 Lowering Springs, Strut support bar, short throw shifter, 22mm Rear Sway Bar w/ anodized upper and lower arms, alta adjustable links, Enkie Rims w falken225/45R17's, custom painted graphics
If it dosen't come when called I don't see a reason to name it!
Old 01-23-2008, 05:30 AM
Gallery
its a hobby of mine to do car audio to this extent. i have an SUV that when finished will hold 24 12" subs and thousands of watts.
i planned on going performance with my new car (when i was shopping, before i got the MINI) and honestly, i was about to buy a mustang, but insurance would have been too much at my age, so thats why i just bought the MINI off my dad.
Old 01-23-2008, 05:32 AM
greengobln's Avatar
greengobln greengobln is offline
Gallery
you could always just take out all that extra weight in the back. just an observation. i would put up stronger front bars and maybe make some executive decisions about how much weight i was willing to add at a loss of the Mini's character hotness in handling. coilovers will drop it in the front to match but honestly you might have added more than you can compensate for which is fine if you only want to the show the car and not try and drive it regularly.
Hi, My name is Brian and I am an OCDetailer
2004 MCS BRG/White
Old 01-23-2008, 05:34 AM
Gallery
only problem is with a mini since it is a performance based car, you are killing the resale value of it and also rendering it useless for its intended purpose.
i get the whole loud music and all, but not in a performance vehicle.
you would far better enjoy the car if you did performance mods and left the stereo to slight mods.
Old 01-23-2008, 05:49 AM
Gallery
Quote:
by extra weight in the back, are you talking about my stereo stuff, or like factory MINI interior stuff?
you have a good point, sometimes i look back and im like "why did i do this in THIS car" but alot of people that are really into audio like it, its different.. everyone around here has SUV's or trucks with massive systems and walls...the only walled off MINI's ive seen are the RF one and i heard JL has one, havent seen it yet, and that one i saw on metacafe walled with like 60 speakers...
resale value...im gonna have this car for a while...im not the type to change cars often...my 97 explorer was my 2nd car (my first car broke after a year) so ive pretty much had the 97 since i was 17 and im 20 now, and have no plans of selling it anytime soon. so ill pretty much drive the MINI until i get my 20k worth out of it its only got 26k miles on it now, 2004...
edit 1- im not into taking cars to the track or anything like that, i never will be, just doesnt catch my interest. so if i went performance in this car, it would just be for fun driving on the street, which in turn would get me tickets! lol.
at least music tickets are a non moving violation and only 76.50 vs a huge speeding ticket/possible arrest LOL!!!!
edit 2- i was going to do a small box behind the rear seats in the beginning, but i cant get by with that little of bass....i gotta have enormous amounts!
edit 3 (lol)- anyone got a link to the JL mini?
Old 01-23-2008, 06:22 AM
minimarks minimarks is offline
Gallery
Adjustable coilovers with custom spring rates is the best way to go and probably the cheapest in the long run to get a proper driving car.. Just my 2 pennies
'06 SB/SB MCS, H-sport Comp RSB, JCW SB, TSW Springs, Bilstein, TSW control arms, Powergrid, Vorshlag Camber Plates, Powerflex, Goodridge, JCW Brake Kit, ADO8/RPF1, 15% Craven Pulley, JCW CAI, K&N, PNI, VIP engine damper, Milltek, Nuvi, Helix Short Shifter, MOMO, GP IC, RMW 450 injtrs, RMW Cam, RMW Header, Jan Tune...
Old 01-23-2008, 08:32 AM
UKCoopeR's Avatar
Gallery
i am not quite sure what you are referring to, that could be torque steer if you meant to say pulling away from a red light, in which case that would be due to fwd.
here are some links that might help:
torque steer: http://www.mph-online.com/mag/streetknowledge/003
under/oversteer: http://www.miracerros.com/mustang/sway3.htm
Old 01-23-2008, 08:41 AM
greengobln's Avatar
Gallery
i was referring to the large wall with mounted magnets and cones.
i would recommend dropping that down a bit. i'm sure you removed as much of the seating as possible and i saw the awesome suede interior bits. i'm all for upgrading audio and interior fab but i'm not looking to add too much weight. JL amp and Sub. JBL components front and back. little extra pop not too much more weight.
also oversteer and understeer are caused when the body of your car doesn't react the way it should to motions of the steering wheel. excess weight will cause the car to slide passed the point at hich you intended to begin your turn. excess tire squeel and a few other things from it.
2004 MCS BRG/White
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
