MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Welcome to North American Motoring, the North American MINI Community of owners and enthusiasts!
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and photo galleries. By joining our free community you will have access to post topics, communicate privately with other MINI enthusiasts (PM), respond to polls, upload your own photo gallery and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact our support team.
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Not a member? Register now!
Welcome to North American Motoring !
» Main Menu
Upgrade Garage
» Latest Main Topics
My first Cooper S
burning mustard colored oily...
Steering Wheel Buttons?
another tire replacement...
I didn't cut the bump stops...
Get vehicle error code w/out...
The most fun production car...
R53 Cooper S JCW GP SIDE/TANK...
205 too wide for snow?
Parking light lens
Advertisement
Vendor
 Aftermarket vendors
View Poll Results: If you had mushrooming or a cracked strut mount please vote
mushrooming: stock suspension / 15" non-runflat tires 9 1.70%
mushrooming: stock suspension / 16" runflat tires 43 8.11%
mushrooming: stock suspension / 16" non-runflat tires 25 4.72%
mushrooming: stock suspension / 17" runflat tires 200 37.74%
mushrooming: stock suspension / 17" non-runflat tires 86 16.23%
mushrooming: stock suspension / 18" runflat tires 15 2.83%
mushrooming: stock suspension / 18" non-runflat tires 11 2.08%
mushrooming: lowering springs / 15" non-runflat tires 2 0.38%
mushrooming: lowering springs / 16" runflat tires 5 0.94%
mushrooming: lowering springs / 16" non-runflat tires 9 1.70%
mushrooming: lowering springs / 17" runflat tires 23 4.34%
mushrooming: lowering springs / 17" non-runflat tires 33 6.23%
mushrooming: lowering springs / 18" runflat tires 3 0.57%
mushrooming: lowering springs / 18" non-runflat tires 14 2.64%
cracked strut mount: stock suspension / 15" non-runflat tires 11 2.08%
cracked strut mount: stock suspension / 16" runflat tires 19 3.58%
cracked strut mount: stock suspension / 16" non-runflat tires 14 2.64%
cracked strut mount: stock suspension / 17" runflat tires 57 10.75%
cracked strut mount: stock suspension / 17" non-runflat tires 25 4.72%
cracked strut mount: stock suspension / 18" runflat tires 5 0.94%
cracked strut mount: stock suspension / 18" non-runflat tires 10 1.89%
cracked strut mount: lowering springs / 15" non-runflat tires 3 0.57%
cracked strut mount: lowering springs / 16" runflat tires 3 0.57%
cracked strut mount: lowering springs / 16" non-runflat tires 7 1.32%
cracked strut mount: lowering springs / 17" runflat tires 7 1.32%
cracked strut mount: lowering springs / 17" non-runflat tires 12 2.26%
cracked strut mount: lowering springs / 18" runflat tires 3 0.57%
cracked strut mount: lowering springs / 18" non-runflat tires 5 0.94%
Multiple Choice Poll. Voters: 530. You may not vote on this poll
Thread Tools Display Modes
Old 04-25-2008, 08:39 AM
digitalinkartis digitalinkartis is offline
Gallery
I have been thinking about this.
Who would be interested in participating in the following:
[SIZE=2]Visiting and documenting mushroom strut tower damage at local mini dealerships selling used mini's. Then simply recording the last 7 digits of the vin of cars with visible damage and writing them on a pre-made form detailing visual confirmation of strut tower damage. This form would then need to be sent to the general manager of the store and a duplicate to BMW NA chairman Jim O'Donnel.
This would force the dealer to fix the problem before sale. Or take liabilty for future developments regarding that particular vin. Once the dealers get hit with the cost they will get an audience with BMW and this will be addressed.
[/SIZE]Just an idea
Old 04-25-2008, 10:34 AM
donjulio donjulio is offline
Gallery
Too much work!
[/SIZE]Just an idea
Old 04-25-2008, 12:30 PM
Dr Obnxs's Avatar
Dr Obnxs Dr Obnxs is offline
Vendor
Gallery
How to work on your struts...
1) Jack front of car up and place on jack stands. You need both sides off the ground at the same time so that you take the stress off the sway bar.
2) Remove wheels (bolts 1-4 per side).
3)Turn steering wheel to one side and lock it. This makes access to the upper end-like bolt (The one on the side of the strut) easier to get to. Take off bolt (bolt #5) and slide through the end-link. Turn the wheel and repeat on the other side.
4) Take the brake line, the ABS sensor wire, and the brake pad sensor wire (if equipped) off the struts.
5) Undo the pinch bolt (big one on the steering knuckle) and remove it (this is number 6...). You have to take it out because it goes through a safety tab so the strut can't come out of the knuckle while driving if the bolt were to loosen.
6) Work the strut out of the knuckle. I rest the bottom of the rotor on a floor jack, and just work it side to side, whack it with a 2x4, whatever. I can slide out pretty easy. Depending on your model year, it may take a bit of creativity to get the drivers side out (at least on very early cars). I'll leave this as an excursize for the student! You want to keep the bottom of the rotor supported cause if you let it droop, it will lean away from the car, maybe far enough to pull the splines out of the tranny, and this is a PITA to deal with.
7) Undo the three top bolts on the strut tower. (bolt numbers 7-9....) Watch out, when the third one is loose the strut will drop. It's pretty heavy (at least to hold with one hand) so go carefull here. Don't worry, you won't break your wrist, just know that it's gonna want drop so be prepared. Once it's loose, you have to thread it through all the lines to get it free and take it out of the car.
8) You can either use the strut top nut tool (a deep socket cut away so you can get an allen wrench into the top of the strut) or an air wrench to undo the top nut. (Number 10!) There isn't much force retianed in the string so you don't NEED a spring compressor. But there is a bit of energy retained in there so be carefull. I've use the air wrench and just leaned into it, or put some ratcheting canvass straps on the spring when using hand tools. Strut compressors can be rented for very little money too, if you like to do things right....
9) once the top nut is off and the spring energy released, you just take off the strut guide and the spring perch, put the new one or ones on, and reverse the process.
It's not hard at all, and now I can drop a strut in less than 10 min. Took about a half hour a side the first time going very slow. If you have lowering springs, then it's even easier.... I don't think there's any energy (depending on spring brand) left in the spring when the strut is out of the car.....
Matt
FES Auto= Worlds Best Shiftlight-Ian Cull Auto-Up-High Current Relay Module-Auto Sportplus
'02 CR/W S, Bunch of fun mods... '08 NFR/S Clubbie, close to bone-stock...
Dr Obnxs' Musings: a blog about cars, energy, technology and more....
'65 Mustang Convertable, 5.0 EFI, 5-sp, 3.55 8.8", GR-350 Suspension, 271 WHP and a big effin' grin!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mushrooming Strut towers. Tiny1 Coupe Talk (2007+) 6 03-08-2008 09:35 AM
Strut Mushrooming MBMoses General MINI Talk 11 05-10-2007 03:29 PM
Strut mount mushrooming, no big deal? minsane Stock Problems/Issues 10 03-10-2007 09:51 AM
Strut Tower Mushrooming Poll RandyBMC Vendor Announcements 0 09-22-2006 09:21 AM
damaged strut towers and mushrooming meb Suspension 1 05-22-2006 08:17 PM
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
Search Engine Friendly URLs by vBSEO 3.2.0
