Rear Washer Problem
Rear Washer Problem
Hiya
I've unblocked the rear washer by blowing air back towards the washer bottle removing all the debris.
However the small O ring that seals the cover to the shaft has fallen to bits.
Its not available from BMW as a separate item and either comes with the cover or motor.
does anyone have any idea what size it is ?
David
David
Hi, thanks for the reply..........I'm in the UK, but I was hoping someone might be able to give me some dimensions........If not I will, as you say just buy a selection...
