6 speed manual not shifting when cold.
Old 02-13-2016, 06:19 AM
Rubidon's Avatar
Rubidon
Rubidon is offline
So I went threw the car wash the other day to get some road salt off the mini and the next morning I could not get the car out of first gear to let it idle and warm up. Now every time I have to let it warm up before it shifts right. After it does warm up it shifts normally, easy shifting with a lot of slop!!
Old 02-14-2016, 04:40 PM
NC TRACKRAT's Avatar
NC TRACKRAT
NC TRACKRAT is offline
Let me venture an opinion: The clutch slave cylinder is your problem. Moisture travels to the lowest point in the system. When sub-freezing temps occur, the slave cylinder locks up and will not function normally, hence you can't shift because the clutch isn't operational.
Old 02-14-2016, 06:21 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Rich.Wolfson is offline
I would say it's not the slave. Change the fluid to Redline MTL and you'll be golden. You're probably due for a fluid change anyway.
///Rich
Old 02-15-2016, 02:16 PM
Rubidon's Avatar
Rubidon
Rubidon is offline
Sorry guys more info, normally with the engine off I can shift through the gears. Now when it is cold and I park it in first gear i can not get it out, with clutch pushed in or not. If I park it in neutral then I cant shift into any gear with or without the clutch. I did check the fluid level and it is low. The clutch pedal always feels the same no matter what.
Old 02-16-2016, 04:28 PM
808keith's Avatar
808keith
808keith is offline
Like Rich said, change to Redline MTL. It made a difference in mine. So when you get things figured out, use Redline MTL.
Old 02-17-2016, 02:15 PM
Rubidon's Avatar
Rubidon
Rubidon is offline
I plan to flush the system with redline with my next oil change. Meanwhile the car is starting to shift when it is cold though with a lot of resistance, makes me Leary to wash it again. Lol
Is there a diy on how to flush the system, I found one but it will not load for me.
Old 02-17-2016, 05:46 PM
Martin Brenneke's Avatar
Martin Brenneke
Martin Brenneke is offline
I think he means to drain the old trans oil out of the gearbox and put the new redline MTL in the trans. I guess you could then run it for a while and do it over to make sure all old trans fluid is out, but I don't think it is necessary. Just run the car around the block and then get trans fluid hot and then drain. Make sure you get the right weight trans fluid to put in trans.
Old 02-18-2016, 06:40 AM
Rich.Wolfson
I don't think a "flush" is necessary. Just drain and refill. The MTL is compatible with the OEM oil. Don't make yourself crazy with this but the MTL will give you as good or better protection and won't be so stiff in the cold.
But getting the fluid in there will require a pump bottle if you do it from the bottom or a funnel on top with a long hose. And if you float the MTL in a hot water bath before the pour, you get get the job done in a half hour on your back in the driveway.
///Rich
Old 02-18-2016, 09:59 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
If you are going to change the fluid we have a tech article that can help. In it we use a hand-operated fluid pump to fill the transmission with the new fluid. There isn't a lot of space to fit a bottle up there so the hand pump is a great alternative. The article covers all of this. Fluid HERE and if you click on MINI and then "tech info" tab at the top and scroll down to Transmission & Axles it's the last one under that category.
888.280.7799 | 6am - 5pm PST
Old 02-23-2016, 11:04 PM
RussWK's Avatar
RussWK
RussWK is offline
Acquired 2006 R52 at 16K miles and noticed 4th took extra effort resulting in missed shift if not careful. After changing to Amsoil Synchromesh tranny oil, all shifts are comparatively light and smooth. And that was after I tried a racing tranny oil recommended by a Mini mod shop which was no better than stock oil.
So, I have Amsoil for all fluids including steering. All is well and smooth operating. Engine oil is Amsoil European Blend 0-40 Full SAPS. Never have had to add between changes.
Old 02-24-2016, 05:45 PM
Rubidon's Avatar
Rubidon
Rubidon is offline
And what would i use in the clutch reservior?
Old 02-24-2016, 06:07 PM
RussWK's Avatar
RussWK
RussWK is offline
I don't know for sure. Maybe brake fluid shared with brake system? I use Amsoil 600 racing fluid which is compatible with regular DOT 3 or 4.
Old 02-25-2016, 10:30 AM
RussWK's Avatar
RussWK
RussWK is offline
https://www.amsoil.com/shop/by-product/other-products/brake-fluid/series-600-dot-4-racing-brake-fluid/?page=%2Fstorefront%2Fbf4.aspx
And yes clutch shares brake system fluid. be careful with bleeding the system of air bubbles.
Old 02-25-2016, 12:54 PM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Fluids are shared I used Ate 200 in both MINI for the clutch/ brake fluid. No issues. Bleed those brakes and the clutch good. Fluid has to meet Dot 4 or higher. all these do.
https://www.ecstuning.com/Mini-2005-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Braking/Fluid/
Old 02-25-2016, 12:58 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
It is combined with the brake system....
Old 02-25-2016, 01:02 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
an extra thought....under the air-box (or where it should be if removed for a CAI) there is the linkage....the joints on it can get dry..and crusty fro salt, and grime...I would lube them up...the other half of the linkages is basically under the shift lever...hidden from below by the exhaust....
Using the wrong oil in the tranny can make shifting HARD when cold....but I would clean and lube the joints on the linkages, especially since you mentioned it got stiff after a car wash....
Old 02-25-2016, 05:34 PM
Rubidon's Avatar
Rubidon
Rubidon is offline
What would you suggest to use on the joints?
partie
08-10-2016 03:00 PM
01-29-2016 02:16 PM
cdavidell
01-21-2016 01:49 AM
cdavidell
01-20-2016 01:50 PM
cdavidell
01-20-2016 01:46 PM
Quick Reply: 6 speed manual not shifting when cold.
