DSC/ yellow brake light
At random, the yellow brake light comes on along with the DSC light. This happens regardless of speed, time, temp, sport mode on or off, straight line cruising on the highway or running errands around town. Anyone else run into this? I have an '07 Cooper S, US model.
Maybe a loose or damaged ABS sensor or it could be something a bit more. I'd check and see if you can pull any fault codes that may give you a better idea. Check out this NAM thread here and here for some info.
888.280.7799 | 6am - 5pm PST
Thanks for all the info, looks like I'll be getting it up on jacks and troubleshooting those ABS sensors first. Just looked up the steering wheel switch (possible cause too) Over $400 online...and it'll have to be programmed at the dealer too? OY! Hope it;s just a quirky sensor in a wheel well!
If you do have DCS and not a rain sensor the part is HERE. If you are unsure shoot me a PM with your vin and I can get you the correct part to fix the issue.
PelicanParts.com
Tires, Wheels & Brakes
03-11-2016 09:23 AM
PelicanParts.com
03-11-2016 09:23 AM
preme123
10-03-2015 08:27 AM
Samhillrocks
09-29-2015 12:55 PM
