Actually, the canister is a cast aluminum affair, rather tidily machined. It's mostly a pain to rethread because the way the filter cartridge sometimes seems to want to tip the canister from perpendicular when reinstalling. It also does not help that two sections of the thread is 'flatted' or missing (a consequence of the die casting process).
I have found that if the canister is being uppity in rethreading, rotating the filter in the housing in 90 degree increments and retrying will often help getting it to line up.
JCW Intake|15% Alta|Milltek Catback|17x7.5 SSR Comps|215/45-17 GS-D3s|Much More
MMC #28|Motoring ID RAGE666
Takes me a few tries, but I just completed my 3rd oil change and have it down pretty well. Easiest method is to place the canister in there and then start threading it counterclockwise (so that you're actually backing it out, not tightening) until you feel it "click" or fall into place, then gently start to tighten it, making sure that it's tightening evenly all the way around.
I agree on the backwards approach. Also be sure to press that filter down into the canister before you start. If it's not popped on correctly, you will have a devil of a time trying to get the canister on.
BLUBELLE - 9/02 production 2003 MCS IB /W 1,2,3 pkgs, Lapis blue interior, Chrome Trim, Magnecors, NGK Iridium IX, Alta 15% Pulley and CAI, Unichip, Scorpion cat-back,Skid Plate, Rear Fogs, H&R RSS Coilovers, Mini-Madness rear suspension poly bushings, RDR Control Arms and Swaybar, PowerGrids end links. Motoring since 10/18/02. I V-1, do you?
Thanks for info. Also, I bought a Fumoto valve for the pan. Any comments on this accesssory? I have the kind with the nipple, because I will be fitting a skid plate, and was told that it can be a mess unless you have a hose to direct the draining oil. Is this a deal where you leave the hose on 24/7, or just attach it when doing an oil change?
__________________ JoeDentist: '05 MC/s Purple Haze,W/W/W, Premium, Sport, Chrono, HK, Red cloth/ black leather, Anthracite headliner & trim, Schroth Harness, Cobalt Skid plate, Wipac Driving lamps - coming soon custom roof mounted light bar "BRUSH OR DIE!"
