2002 no tachometer or dash lights! checked everything!
Just recently picked up a 2002 MINI COOPER BASE. Amongst other issues it had, the last thing im trying to fix now is the tachomter not working (needle or lights dont work) and no dash lights work other than the radio and odometer.
I removed all the carpeting and checked the bcu and all the harnesses, luckily there little/no water and everything looked good. I even let the bcu sit in the sun for a few days to be safe.
Ive also tried a different tachometer and speedometer. All Fuses seem to be good
all gauges on the speedometer work except the backlights, and the trip meter always resets to zero every time i start it.
and help would be great
thanks
thanks
I have a 2002 S that is also started doing this after I had replaced the clutch . I still haven't figured out the cause but I have exact same issue. No tach gauge at all it is dead. No dash lights or back illumination on the speedometer gauge and trip meter resets every Time. I do have some signs of water around bcm but can't afford to change it . I have an extra tachometer out of a wrecked car that I will swap too and post results if any .
thanks
thanks
Please help.
This has been intensely frustrating. Occasionally, and maybe related to a rain event, imy R50 does the following. The tachometer stops working, dash lights all light up, the CVT starts shifting very erratically, (like to first gear on the highway). Sometimes clearing the OBDII codes fixes it completely for two weeks.
It seems like the "rain in the BCU problem" but I don't see any sign of water. I've had the MCU out and checked, soaked the wiring harness in the cowl area to no affect. The BCU looks fine but there are many splices in the harness to the four connectors (look like old dealer repairs).
As bizarre as it seems for a $1000 car, I'm planning on replacing the entire wiring harness, the BCU, the MCU, and the battery box and lid.
And I don't know if this will even resolve the problem.
Peter
Peter
AFAIK the BCU doesn't control the dash lights/gages. All of this information comes from the ECU through the X15 connector in the drivers footwell just below the fuse panel. If you've had sunroof drain leaks this will likely have been submerged and the connector is probably corroded.
https://www.newtis.info/tisv2/a/en/r...345200/UzFjVpY
I'd suggest taking this out and looking at it. If it is corroded, try and clean the pins, or hit them with flux and a soldering iron to remove the oxidation that is likely on them.
This is all assuming you've verified fuses are good , but if your whole dash is out its probably not a fuse issue as you'd have to have many that were blown. X15 is really the only culprit that would connect everything.
07-16-2020 12:54 PM
triple5soul
21
07-29-2016 04:27 AM
nismo4life
08-05-2015 08:31 AM
