remote control Key Mini One r50 pre-restayling PROBLEM!!!
Hello boys I've a PROBLEM with my remote control key.
Start:I bought MINI used and the remote control key never work.
I can't open my MINI with remote control, i have try synchronize the remote control with car , i have try rebuild the barcode of key and insert as the barcode in the BC1 via DIS v44, but the my barcode is correct in to the BC1.
finally i have seen that hadn't the reciver 433 MHZ below the clock.I bought the receiver , and the diagnostic program INPA receives the remote control signal, but the car not open/close the doors.
i have seen in NCS expert if the function was activate, it was ok.
The remote control work correctly the signal is correct on 433Mhz tested TESTER
Help Me PLEASE. I don't know where to look and how to solve.sorry for my English.
P.S. I have the remote control with two buttons.
Is the remote key the original to the MINI or did someone buy one off of ebay and give it to you when you got the car as a backup ?
Pre 7/2004 keys can be programmed by MINI , post 7/2004 Gen 1 Key you can use the flash technique yourself.
https://www.northamericanmotoring.co...-question.html
Dont know about NCS expert.
I have just received a key from the seller other two keys had lost the old owner. the Key and remote control are original this is my key the blade is VALEO and the case is not original because original case was broke.
I've try to sync the key with the car but never work.
07-16-2020 12:54 PM
ClayTaylorNC
08-10-2015 09:19 PM
Ambient Thermal Management
08-07-2015 12:27 PM
PelicanParts.com
08-04-2015 02:45 PM
