2003 MCS Electrical Problems (Blower,Wipers,Hatch)
Old 08-02-2015, 10:48 AM
jradcliffe02's Avatar
jradcliffe02
jradcliffe02 is offline
Hello again:
I am chasing down some ghosts in the 2003 MCS I bought. Initially I thought that everything would be fixed when I bypassed the corroded 42 pin connector hear the fuse panel on the left side of the car. That helped fix many of the issues I have with the car. There are some really odd ones that remain.
-The blower for A/C only runs if the car is in accessory. When I start the car it does not run. When in accessory mode all the fan speeds work no problem. Fan doesn't run at all when car is running.
-Hatch switch no longer opens the hatch. I verified that the switch is not the problem. (it makes to ground when pressed like it should)
-Wipers have a mind of their own. It's worse when the car is running. Only run on one speed and don't turn off after being turned on.
-Power windows on both sides "pulse". Only moving 1" at a time until fully open or closed.
-Power locks are not working.
My initial thought was BC1/BCM. I pulled it out and it is completely dry. No signs of corrosion or history of water. I also tried pulling F27 and removing the radio from the equation. It's and after market Sony through a Metra harness. That also made no difference. I also did a full ECM reset via key Viagra method. Looking over the Bentley manual I am not sure if there is a common element to all of these issues. If I had a spare BC1/BCM I would certainly try it. I would check the battery, but alas I can not open the back hatch. It is less then two years old and shows almost 13v. Starts the car with no issues.
Any help would be appreciated!
Old 08-06-2015, 03:32 PM
jradcliffe02
ttt
Old 08-10-2015, 01:08 PM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Did someone replace the whole stereo and cut things up for an aftermarket amp ? Possible they cut into or tapped a power line.
alistaircookie
10-08-2015 10:52 AM
PrimePower
08-16-2015 06:29 PM
Terry Gallentine
08-11-2015 03:31 PM
PrimePower
08-11-2015 12:51 PM
08-07-2015 08:02 AM
Quick Reply: 2003 MCS Electrical Problems (Blower,Wipers,Hatch)
