How to replace CLUTCH LINE ?
Hey all,
Tonight, while working on my car, I accidently damaged the actual "clutch line" that stems from the firewall -> Clutch slave cylinder. Ugh my stupidity at its best..
Its this part:
http://www.ecstuning.com/ES41527/
http://www.realoem.com/bmw/enUS/show...diagId=21_0178
#11 on RealOEM.
Anyhow, I've poked around and peeled the rubber gourmet at the firewall but the hole behind it is small and I can't really see anything through it.
I know it will be disconnectable but where can I access it?
I am guessing master cylinder area but I was unable to really see much.
Also, if its right at the master cylinder area, after disconnecting / replacing, will I need to bleed the master cylinder, along with the slave cylinder?
Kinda frustrated but I am taking it slow.............................. :\
THank you in advance!
Its this part:
#11 on RealOEM.
gmonde
09-08-2015 06:37 AM
Powershift
08-16-2015 05:14 PM
Colt45Magnus
08-12-2015 06:43 AM
