r56 Kazoo sound, no boost!
I recently got the kazoo sound after shutting down, and found a thread relating it to the pressure converter. After replacing the pressure converter, I drove it around the block and had no boost and the half power engine light.
Is it possible I used the wrong pressure converter? the car is a 2010 and I ordered from http://www.ecstuning.com/News/MINI_R...013_2014_2015/
The car isn't modified at all and was making boost before the change.
Let me know if you have an issue with the part or contact or customer service and we can take care of you.
We have no had any issue with this part as its made by the same company Pierburg, that make the Genuine MINI one. Just better pricing. Also make sure when installed the connection is tight on the vacuum line ( and the vacuum line is not split ), also on the plug.
07-16-2020 12:54 PM
Indimanic
08-19-2015 11:08 AM
Ambient Thermal Management
08-07-2015 12:27 PM
