09 Cooper hesitates up to 2000rpm
Old 06-16-2015, 07:57 AM
ainetsc's Avatar
ainetsc
ainetsc is offline
We have a 2009 Cooper base which hesitates in any gear up to 2000 rpm, over 2000 rpm there is none.
We are getting 38 mpg with AC on as it's stupid hot here in VA so it does not seem like a misfire.
any idea's?
Old 06-16-2015, 09:12 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
First thing I'd do is pull the spark plugs and see what they look like.
Old 06-16-2015, 09:38 AM
Roca68's Avatar
Roca68
Roca68 is offline
I had a similar issue. Replacing the spark plugs did the trick.
Old 07-03-2015, 05:53 PM
ainetsc's Avatar
ainetsc
ainetsc is offline
09 Cooper hesitates to 2000 Rpm
Plugs look well worn they have BERU plugs - ant recommendations for replacements?
Old 07-12-2015, 12:01 PM
ainetsc's Avatar
ainetsc
ainetsc is offline
Put new Bosch plugs In which did the trick - thanks!!!
Now to find that rattle from the boot area!!!!!!
Old 09-29-2015, 10:51 AM
BossyR56's Avatar
BossyR56
BossyR56 is offline
I just got my car back over the weekend and they replaced the thermostat and coolant. No more loud sound when turning off the car however the car is hesitating starting at 2 rpms again. Spark plugs were just replaced in July ... and thoughts?
Old 10-08-2015, 07:30 PM
Systemlord's Avatar
Systemlord
Systemlord is offline
That aux pump for the turbo can buzz pretty loud when there's air in your cooling system. If you have ever had an aquarium you know those pumps buzz because there is water and air bubbles going through them.
Old 10-08-2015, 07:37 PM
BossyR56's Avatar
BossyR56
BossyR56 is offline
Ended up taking the car back to the shop and they replaced the clutch. Didnt really think it was the clutch causing the hesitation but so far the car is running great! Knock on wood.
Old 10-08-2015, 07:51 PM
Systemlord's Avatar
Systemlord
I had my clutch and flywheel components replaced recent and in second gear if you let it get to low in the RPMs it will start jerking back and forth, now that's a clutch with some grip!
Old 10-08-2015, 08:00 PM
BossyR56's Avatar
BossyR56
BossyR56 is offline
How much did you end up paying if you don't mind me asking? The used car dealership whom I bought my mini covered the repairs.
Old 10-08-2015, 09:15 PM
Systemlord's Avatar
Systemlord
I ran over a big tire on the freeway that was 100% percent unavoidable and that's when my throwout bearing started whistling/squealing, should have seen the Mercedes buck upwards that ran over the tire first! So my car insurance paid for the labor ($1900, Mini dealership) and $1400 for the parts.
I found many online places that sold the same geuine Mini clutch and flywheel parts for $869 (ECS Tuning ), but the Mini dealer wouldn't warranty a part that wasn't ordered through them even though it was a Min part.
Old 10-17-2015, 07:47 PM
BossyR56's Avatar
BossyR56
BossyR56 is offline
They replaced the clutch. Problem solved.
Teh
06-13-2018 02:59 PM
yashmack
08-15-2015 10:16 AM
08-12-2015 01:24 PM
08-07-2015 08:02 AM
PelicanParts.com
08-04-2015 02:45 PM
Quick Reply: 09 Cooper hesitates up to 2000rpm
