Driving lights harness connectors...
looking at the install instructions here
http://www.minimania.com/pdfile/R56_Rally_Lights.pdf
are you talking about parts K and/or L (see parts list page 4)
if so .... cut the connector end off and use a generic connector (spade type would work fine) or just solder things up and water seal (I'd use heat shrink tube)
nothing special here, you are just connecting a 12v line and a ground to each light. Do you really need a connector in between? The connector is just another place for water to get in a cause a short! I'd solder and heat shrink . . .
Wohnson89
06-10-2020 04:53 AM
ryGuyMCS
10-20-2015 02:24 PM
JHolland
08-13-2015 10:47 PM
nismo4life
08-05-2015 08:31 AM
