common problem with an odd twist
I have a 05 S convertible. I am having the DSC/tire pressure light issue (no abs light). I searched the forums and found that the steering angle sensor is usually the cause. I am just curious. When I start my car the lights don't come on. They only illuminate when I release the parking brake (i always apply the parking brake when I park). Is that normal with this issue or should I be checking other things? just before this problem started I noticed the 2 lights would occasionally come on when I hit a bump but turning the car off and restarting it would shut them off. Now they are always on once I release the parking brake although every once in a blue moon they won't come on.
Also, have you plugged in a code reader to your OBD II port for codes? It may help narrow down the culprit.
Like I said... stab in the dark.
sdotbailey
R55 :: Clubman Talk (2008+)
09-16-2015 09:03 AM
PelicanParts.com
08-04-2015 02:45 PM
