2003 MCS Bonnet Cable/latch
Hello,
I'm a newbie to this forum and I have a question. Recently, either due to the cold and/or age of the car, the driver side bonnet will not latch when I close the hood. I WD40'd everything (later to add white lithium grease) to see if it would free anything up that was stuck, but no luck. I think the cable is stuck at the interior latch. Would replacing the cable set fix this? Is this a known problem? How easy is it to replace the cable set?
Thanks!
Thanks!
The interior part (that you pull on) is a lever held on by a few bolts. You can remove that and check that the cables move freely (and that the cables are still in the slot). Replacing the actual cable is more involved - because it feeds to two latches, there are two cables - the far side cable routes along and under the front of the windshield so a lot of stuff has to be removed to get access.
alistaircookie
10-08-2015 10:52 AM
R50/53 Replacement AC compressor??
PrimePower
08-16-2015 06:29 PM
