Transmission fluid flush?
I've been to both MINI of Dallas and Sewell MINI before when I was under the maintenance program and they both would not do a transmission fluid flush. They both claimed the fluid is maintenance free! Ugh, I can't believe this. If it's "maintenance free" then why is my shifter stiffer than normal? It now seizes up slightly when moved from one gear to the next.
Does anyone have a picture tutorial on how to do a transmission fluid flush? How do you pour the new transmission fluid into the case? There's no inlet for it anywhere in the engine bay.
https://www.northamericanmotoring.co...n-6-speed.html
You can also use the site's search feature, "Automatic transmission fluid change" and you'll find many posts about how to do it yourself.
Dave
Dave
Dave
Dave
Just be careful to collect and measure all old fluid that you drain out (I bought a large open pan just for that reason), and fill her back with identical volume of new OEM fluid. I went with OEM fluid as savings from using Toyota/VW fluid (same spec) wasn't worth the headache for me.
a
Local independent quoted $400 + cost of fluid.
Both were intimately familiar with the service, and performed it numerous times in MINI's.
a
I followed the above link (and few others on this forum) to drain/refill 3 quarts (out of 4) of slushbox fluid about a year ago. Car/tranny had 56K miles at the time. There was an appreciable improvement in shifting smoothness, especially during kickdown under load.
a
a
5mm allen wrench. same size for the plastic standpipe after you remove the drain plug. do more research before doing anything else.
